BORLA
Old 08-07-2012, 03:45 PM   #1
Neto1978
Drives: 2011 camaro ss victory red
HYPERTECH MAXENERGY tune worth it?
The only mod I may apply to my camaro is a tune.
I would like to know if hypertech could give good gains in hp.
One thing I consider is that I will only use regular fuel (87 octanes).
and will disable the AFM,
no torque management mods.
I don't want to know wich tune is better, I just want to hear from hypertech owners
tks.
Neto1978 is offline   Reply With Quote
Old 08-09-2012, 06:59 PM   #2
Jcm
Drives: 2011 ss
Got the same car and color as you ,I did have the the hyper tech I installed,yes it did make a ton of difference ,my car had flow masters on it when I bought it.that afm blurbing wast errible.that alone was worth the money getting rid of that..but then a couple months later a speedshop owner friend gave me a deal on a complete stainless works exhaust system , long tubes ,high flow cats, three inch pipes,with chambered mufflers . And included a new Dyno tune. So I unmarried the hyper tech before the tune. But I can tell you the hyper tech made lots of difference in mine. Idles smoother,more power ,no blubber. And I could sell you mine for 200. If you like.
Jcm is offline   Reply With Quote
Old 08-16-2012, 08:56 PM   #3
grocerygetter
instigator
grocerygetter's Avatar
the hypertech tune is great...I actually beta tested on it. Its great for a stock car with maybe an air intake and a catback. It also does gear adjustment now (I think). If you go further...such as headers etc...you probably should go a different route.
But just an fyi...I picked up like .3-.4 at the dragstrip with it. That's not all hp...also tranny tune and driveability. This was on my first camaro...the silver one.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 08-17-2012, 12:52 AM   #4
alanhurst
Master Chief
alanhurst's Avatar
Drives: 2011 Camaro SS RS L99
tks.
why only 87 octane? the SS pretty much demands 93,unless you have no other option you should be using 93. (disregard this if the fuel ratings in your country are different and your 87= our 93)
the car will cut power with regular fuel and i dunno how much good a tune will do you while running regular fuel.
alanhurst is offline   Reply With Quote
Old 08-22-2012, 02:39 PM   #5
grocerygetter
instigator
the hypertech will do everything you asked. TM can stay left alone or reduced. There is a 87 and a 91 tune both you can choose in the menus. afm can disabled as well.
-John S.
Thanks to:
Tony@ dv8motoring
Old 09-18-2012, 01:19 PM   #6
Ponykiller511
Ponykiller511's Avatar
Drives: 2012 RS/SS L99
AFM delete is awesome.
2012 RS/SS L99 Silver Ice Metallic
Texas Speed custom cam and Whipple 2.9
533/529 with TES tune
Pfadt Stage 2 kit with ZL-SPEC sway bars and rear arm kit
Pfadt Coilovers
Pedders Stage 1 bushings / BMR Subframe connectors and tunnel brace
American Racing long tubes w/ high flow cats
CAI Intake / Rotofab washer bottle / Roto Fab engine covers/JRE race scoop/Forgestar F-16
/Oracle LED side markers, backup lamps and DRL
DYI 5 DRL harness / Heritage Grill
[SIGPIC]
Ponykiller511 is offline   Reply With Quote
Old 09-30-2012, 10:34 PM   #7
parkerss
parkerss's Avatar
Drives: 2013 SS M-6
I have a Hypertec. Very happy with it!! I changed everything I could .... You have a lot of options to choose from. I would HIGHLY recommened it! I like it when other Camaro owners hop in and there like WOW! What have you done and I say its stock LOL
Speeding is fun, Speeding with friends...PRICELESS!
parkerss is offline   Reply With Quote
