IPS Motorsports
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 08-08-2012, 09:52 AM   #1
maxxer442
Drives: 2010 IOM 2SS M6
Launch control failure(axle)
So my 2010 SS M6 has around 10,000 easy miles on it-all from me. No racing, just run it thru the gears once in a while, no hard launches. I have tried the launch control like twice when I first bought it way back in 09. Didn't like it, its too violent. I had a buddy with me the other night, and he wanted to see how it worked. So I put it in the mode, it worked like it was supposed to, until I dumped the clutch and broke the right side half-shaft. What the heck! Is this a fluke? Do I have to worry about ever using that again? The car is bone stock with catback and a hurst short-throw. It was covered under warranty with no questions asked-but is this common?
maxxer442 is offline   Reply With Quote
Old 08-08-2012, 10:00 AM   #2
RacnJsn95
RacnJsn95's Avatar
Drives: 2010 1SS Camaro; 72 Chevelle
Send a message via AIM to RacnJsn95 Send a message via MSN to RacnJsn95
I've read of a few occurences. The general concensus I see is, use the factory launch control, and break stuff. I've used it twice and experienced violent wheel hop both times, I don't think I will ever use it again. Glad you got it covered under warranty!
Specializing in attractive "no drill" front license plate brackets for the 2010+ Camaro Check out our new website! www.jacfab.com
2010 Camaro 1SS RJT w/ SIM Stripes; M6. 12.535 @ 112.33mph JacFab No-Drill front license plate bracket, Dynomax Axleback, JacFab CAI System, JacFab HFC's, ported TB. SOLD!
2013 Camaro 2LS SW w/ IOM Stripes; A6. Just breaking her in, then the fun begins.
RacnJsn95 is offline   Reply With Quote
Old 08-08-2012, 10:04 AM   #3
Russell James
Russell James's Avatar
Drives: '12 SS/RS LS3 IBM
Forget that feature is there and never use it.
Too many variables to not avoid busting something. Road grip, tire pressure, temp, clutch grip, alignment.... get the right combo that causes wheel hop and parts will break.
Lucky it was just the axle and not the driveshaft that can destroy the exhaust and belly pan of the car.
Old 08-08-2012, 10:23 AM   #4
HumanWiki
Former 5th Gen owner
HumanWiki's Avatar
Drives: 2012 IOM Grand Sport 4LT
^ Ditto.
LC on the SS is just a nice little toy that you'll roll the dice on every time.. It's ultimately useless and a decent driver will outrun it every time.
2012 IOM Grand Sport 4LT Auto
HumanWiki is offline   Reply With Quote
Old 08-08-2012, 10:26 AM   #5
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
one of the issues is the rear axles are made from a carbon material and will have a wide range of results as far as breakage. Retained Austenite in the material is the culprate (along with wheel hop) this is why the failures are not as consistent as most would like to see. some of the axles will last for some time and with allot of abuse and others will fail quickly. this is why the aftermarket will use Chromoly materials that are a cleaner bland to start with so there is much less or no Retained Austenite.
How Does Retained Austenite Affect Performance?
Hardening of steels requires heating to an austenitic phase and quenching to room temperature to produce a hard martensitic phase. Due to incomplete transformation some austenite is retained at room temperature. Retained austenite can have a detrimental affect on the mechanical properties of the steel. Properties such as fatigue strength, toughness, hardness, yield strength and machinability can be influenced by retained austenite
The Driveshaft Shop
Any of the parts we post about can be
purchased thru our extensive dealer network
If you want to see some of our latest Hi-Tech stuff click the picture below....
Driveshaftshop is offline   Reply With Quote
Old 08-08-2012, 10:29 AM   #6
mclark10
mclark10's Avatar
Drives: 2013 CRT ZL1 Vert M6, 2011 Equinox
Are our axles yet another high quality item made in China?
Cosmetic Mods- A few
Performance Mods- Even fewer
mclark10 is offline   Reply With Quote
Old 08-08-2012, 10:56 AM   #7
Driveshaftshop
no, but in the beginning CV axles were made from a much higher grade of material. as time went on they were able to understand the way there made and what it can take. on a scale from 1-10 if an axle needed to handle say a #5 it would be made to #9 now the axles that need to handle #5 are designed for just over it like a #5.5 its not that there made bad, there just being made to do what it was intended for, no more.
The Driveshaft Shop
Old 08-08-2012, 11:03 AM   #8
Kiernans88
TRI-COUNTY CAMARO TAMPA
Kiernans88's Avatar
Drives: 2011 Camaro SS/RS IBM M6
+1
This put a smile on my face. Iron/carbon phase diagrams oddly excite me!
FSP Custom Grind Comp Cam - K&N CAI - 1 3/4" BBK Full Length Headers - BBK High Flow Cats - Kooks 3" Street Screamer Catback - VMax TB - Barton Short Throw - 20% DRL, Marker, Tail Light Tint - 20% Window Tint - Carbon Fiber Emblems - Dyno Tuned by Florida Speed and Power - 455 RWHP / 413 RWTQ (MUSTANG DYNO)
Kiernans88 is online now   Reply With Quote
Old 08-08-2012, 10:37 PM   #9
GFORCE1320
Drives: 05 GTO
It all boils down to the cheaper the steel, the more inconsistent results you get.
There are lots of different steel one could use for drivetrain parts.
We have tested just about every material there is that is suitable for making drivetrain parts from and we also do material analysis on OEM parts to see what they are made of and why they fail.
You would be surprised at what kind of mixtures steels and low grades the OEM's use. Some of the materials the OEM’s use are not even on the engineering standards charts..
As far as aftermarket axles, we don’t use chromoly steel, it's a 41xx series steel from the Chromium-Molybdenum family hence the commonly used name Chro-moly.
We've never had much luck with it and the tensile strength isn’t as high as say 4340 or 300m.
4340 is from the Nickel-Chromium family of 43xx steels and is not chromoly, 300m is a modified version of 4340. 300m is not a chromoly either. Totally different material.
To get drivetrain parts to live under extreme conditions, the material has to be able to survive high impact loads, be able to twist without breaking and spring back to it’s original state.
The automotive OEM's could produce some really great drivetrain parts if they wanted to but when they are cranking out cars by the 100,000's of thousands, spending an extra $100. on materials would really add up.
So they only design parts to live up to normal driving and warranty anything that breaks.
I love experimenting with different materials, seeing how they come out as far as tensile strength tests and also how they machine in our cnc machines.
Sorry if I rambled on but this stuff is what I love to do
Gforce Engineering
LIFETIME WARRANTY!
The Leaders in IRS Drivetrain Technology
gforce1320@gmail.com
www.Gforce1320.com 316-260-8433 or 8439
GFORCE1320 is offline   Reply With Quote
Old 08-09-2012, 03:47 AM   #10
2012-2SS
2012-2SS's Avatar
Drives: 2012 Camaro 2SS/RS
Since when do our camaros have launch control?
2012 Camaro 2SS/RS, Hurst Short Throw, IdealG M/C, Pypes Pipe Bomb, LSR Cold Air Intake, LSR Toe Links/Lower Control Arms Clear Image headers, high flows, Slowhawk tune
1974 Chevy K10 Built 355, FAST EZ EFI, 4speed
2000 Chevy Tahoe LT 5.3L, Slowhawk tune
2012-2SS is online now   Reply With Quote
Old 08-09-2012, 10:53 AM   #11
Higgs Boson
Big Time Newb
Drives: C63
http://www.camaro5.com/launch-control-demo-information
Higgs Boson is offline   Reply With Quote
Old 08-09-2012, 11:05 AM   #12
mclark10
mclark10's Avatar
March 16, 2009. Fleet test cars before that.
Old 08-09-2012, 11:32 AM   #13
carbon8
carbon8's Avatar
Drives: 2010 Camaro SS,2008 Hayabusa
Can anyone show pics of where the axels break at.
Sent from my iPad using Tapatalk HD
carbon8 is offline   Reply With Quote
Old 08-09-2012, 12:10 PM   #14
Higgs Boson
Big Time Newb
Drives: C63
they usually twist off one of the ends.
Old 08-09-2012, 02:20 PM   #15
Driveshaftshop
check this out, this is a guy from Canada that changed the axles out on his car and didn't even know they were this bad.
The Driveshaft Shop
Old 08-09-2012, 03:43 PM   #16
maxxer442
Well, after all these posts to answer my question(thanks to you all, btw), I find it rediculous that I can't drive my $40k car aggressively once in a while, let alone attempt to hook it up at the track without fear of this happening. Shoot, my 400whp 4th gen had the "weak" 7.5 10 bolt in it and it lasted 85k miles! And I beat the crap out of that car! And I was about ready to start doin stuff to this car! You're saying $1500 axles are my only hope??!!
Old 08-09-2012, 03:58 PM   #17
1badtie
1badtie's Avatar
Drives: 2010 camaro 2ss rs
I worry about this therefore i try my hardest to be as easy as possible on my car
I get extreme amounts of wheel hop when I have done some hard launches in the past
I only have an exhaust on my car as well this is why i want the zl1 i like the warranty that comes with it
:5thgenvert:
1badtie is offline   Reply With Quote
Old 08-09-2012, 04:14 PM   #18
Driveshaftshop
We do have the 1000hp anti wheel hop axles in stock and will stop the problem if your interested.
The Driveshaft Shop
Old 08-09-2012, 04:27 PM   #19
Higgs Boson
Big Time Newb
Drives: C63
You can drive it. You just have to do it right....
street tires won't hook and therefore you won't break an axle. However, radial tires can wheel hop and break an axle.
you have to drive between those lines and you're good. otherwise, axles before the supercharger....
Old 08-09-2012, 06:44 PM   #20
GFORCE1320
Drives: 05 GTO
Anti wheel hop axles are about the only way to keep it from breaking axles if your going to be racing or even spinning the tires hard.
Our anti wheel hop axles work great at eliminating the wheel hop to where all you get is nice smooth tire spin.
Thanks
Chris
Gforce Engineering
LIFETIME WARRANTY!
Old 08-09-2012, 06:53 PM   #21
Higgs Boson
Big Time Newb
Drives: C63
Thanks
Chris
how do they work, what makes them anti hop rather than simply bulletproof?
Old 08-09-2012, 07:05 PM   #22
Driveshaftshop
The way we have done it is to use 300m material and roll the splines onto the bars, one side is 1.166 and the other is a full 1.500 the way it works is the axle twist up and release at different rates allowing the tires to spin. the factory axles are made this way but don't quite work as well as our design. take a look
there made with billet 4340 cages and the center bars are 300m (not 4340 make sure you get 300m because the weight of the car will break 4340)
we do offer a forum discout also
The Driveshaft Shop
Old 08-09-2012, 07:12 PM   #23
GFORCE1320
Drives: 05 GTO
Keeping the axles from wheel hopping will go a long ways in making them bullet proof.
If you make a strong axle out of high alloy materials plus give it an anti wheel hop design like all of our axles have then you have a really well engineered axle.
You have to stagger the diameters of the axles from side to side to absorb the harmonics of the wheel hop.
We started our anti wheel hop axles with the CTSV market and carried it over to the GTO, G8 and the Camaro market.
What happens when you get wheel hop is this.
The axles are always in a constant state of twist under acceleration, doesn't matter if it is a clutch dump or just rolling into the throttle hard.
When you break traction, the axle unloads and twists back the opposite way. When it does this, the tire gets a chance to get traction for a split second and bites into the pavement, it then slightly "hops" into the air from the momentary bit of traction and the sudden unloading of the axles.
Then the same thing happens on the other side a split second later and then it goes into a chain reaction from side to side until you let off the gas (or break something).
I hope that all made sense.
Thanks
Chris
Gforce Engineering
LIFETIME WARRANTY!
Old 08-09-2012, 08:28 PM   #24
Higgs Boson
Big Time Newb
Drives: C63
very cool guys.
Old 08-10-2012, 01:26 PM   #25
newmoon
newmoon's Avatar
Drives: 2012 5.0 Mustang, Brembo Track Pack
It really is ridiculous that you have to spend $1500.00 on aftermarket axles, and another $1800.00 + installation costs on a quality clutch to have faith that when you drop the hammer on your stock or near stock vehicle you are not going to break something.
Presently Car-Less
2012 Ford Mustang 5.0. Brembo, 3:73s
2012 Challenger 392 auto 12:40s 112 stock
2010 SS, LS3, Cammed, LTs, NT05R,12:20s
newmoon is offline   Reply With Quote
