Solo Performance
Old 08-20-2012, 01:19 AM   #15
pistolgripcopo1
pistolgripcopo1
pistolgripcopo1's Avatar
Drives: 2010 SS Camaro Carbon fiber gray
30 day money back gerentee notify barton.
pistolgripcopo1 is offline   Reply With Quote
Old 08-20-2012, 05:41 PM   #16
Barton Industries
Barton Industries's Avatar
Drives: 2010 Camaro SS
Kevin1106- Some cars make more noise than others, this is out of our control. The looser the tolerances are on GM's side the more drivetrain noise will transmit through the shifter. This is why some have noise and some dont, with ANY shifter.
If you had no noise with the MTI shifter its because you were using the factory knob or a different style knob than the shift ball that comes with our flat stick. If you use our OEM type stick so you can use the factory knob. You will have no noise at all.
With the flat stick and ball, you have no rubber isolation between the handle and the knob. If you apply some teflon tape to the upper threads and put the ball back on, it should quiet it down. If for some reason you still have noise, make sure the rubber boot inside the car is pulled back up on to the handle and not sitting below it. The boot on the bottom of the car may also not be properly seated all the way. Also, did you make sure the "D" on the bottom of the shifter was to the drivers side?
If everything is correct, than shoot me an email with your address and I will send you an OEM type stick so you can use the factory knob, to eliminate the noise. Free of charge.
As far as material quality, we use 304 stainless steel and 6061 T6 billet aluminum. Yes, our bushings are not roller bearings like the MTI, but there are no need for bearings on a linkage. The shifter linkage is applied through linear force not a rotational direction. You might get 1/10 of a rotation in the pivot pin but bearings are designed for rotating not applying pressure. Same reason you use bushings on control arms and not roller bearings.
Thanks,
Dave
Barton Industries is offline   Reply With Quote
Old 08-23-2012, 09:26 PM   #17
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
PM sent...
kevin1106 is offline   Reply With Quote
Old 08-31-2012, 02:41 PM   #18
Brandon@LSRPerformance
Drives: N/A
Check out our Tri-Ax shifter:
  1. 20%-33% reduced throw
  2. Durable delrin linkage insert
  3. Long lasting billet steel and aluminum construction
  4. Will not corrode, nickel plated
  5. Made in America
  6. Lifetime warranty - We make it, we guarantee it!
Let me know if I can help you with that.
Brandon@LSRPerformance is offline   Reply With Quote
Old 08-31-2012, 11:00 PM   #19
kevin1106
kevin1106's Avatar
Sent a pm to Barton's. 8 days later, no reply's and no shifter. Pulling it out tomorrow and sending it back. Going with MGW.....Before my 30 days is up.
Old 08-31-2012, 11:03 PM   #20
kevin1106
kevin1106's Avatar
  5. Made in America
Pm me a price please....
Old 09-04-2012, 12:26 PM   #21
Drives: N/A
PM sent.
Old 09-04-2012, 01:10 PM   #22
kevin1106
kevin1106's Avatar
pm replied....
Old 09-08-2012, 11:56 PM   #23
kevin1106
kevin1106's Avatar
Thanks,
Dave
Just figured I'd give an update.... As of today, still no reply from my pm and of course no shifter....guess I won't be getting my free shifter after all. Almost 3weeks
Old 09-09-2012, 07:38 AM   #24
TRIPWIRE
Chillin Like a Villain
TRIPWIRE's Avatar
Drives: 2013 2SS Blue Ray Metallic Dusk Ed.
dude he said to email him go to the site and find the email you gotta get that free shifter lol
TRIPWIRE is offline   Reply With Quote
Old 09-09-2012, 07:54 AM   #25
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
I dont why people pm. Call them. If you cant speak with a live person then why do business with them imo.
Sent from my DROID BIONIC using Tapatalk 2
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 09-12-2012, 11:28 PM   #26
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
some people may be surfing at work.. .. just a thought.
franknbeans is offline   Reply With Quote
Old 09-15-2012, 06:48 PM   #27
kevin1106
kevin1106's Avatar
Very true, and when I pm someone and see that they were last active today... And they don't reply.... That means.... F off, we only said that to look good on the forum.... You not getting anything free.... So my mistake.... Should have never bought the Barton shifter... I just took 200+ dollars and rolled down my window going 70mph and through it out the window..... That's how I feel....
I actually just purchased the MGW shifter tonight, as RPM transmission recommend that particular shifter to me... I should have purchased it awhile ago....
Old 09-15-2012, 08:09 PM   #28
RxDoc08
Jason
RxDoc08's Avatar
Drives: 2011 2SS/RS M6
I hope someone can give me a definite answer on this one. I was told by the guys at the Barton booth at Camaro Fest that if you have the stock Hurst shifter option that their shifter will not be compatible. Can anyone confirm or deny?
RxDoc08 is offline   Reply With Quote
barton, hurst
