HeadlightArmor
Old 08-08-2012, 10:03 PM   #1
sebi1990
Drives: 2012 v6 LFX M6 Black Camaro
Lunching my 2012 v6 m6.
Guys I've been to the track for the first time with my camaro an in my life and I feel like i couldn't lunch t very well. My best time was 14.8 which is caused partial by the 95 Fahrenheit temperature. My question is what are good lunching revs and how do i lunch the car so that it is the most beneficial. BTW i find the amount of room in the clutch pedal before it engages very annoying.
sebi1990 is offline   Reply With Quote
Old 08-09-2012, 01:50 AM   #2
sebi1990
any1 plz?
2012 Camaro v6 LFX M6. Black. Hurst Short Throw Shifter, Muffler Delete. Best track time: 14.8s
Old 08-09-2012, 04:57 PM   #3
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Try rolling out the clutch instead of dumping or letting it spring back ultra-fast. Maybe start at 2500 and work your way up a bit to see what works best.
In other words, let the quick out more quickly than a standard easy take off but don't drop it. Make sense? Practice is the key.
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 08-09-2012, 05:10 PM   #4
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
you gotta slip it a bit. and its launch, not lunch.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 08-11-2012, 01:13 AM   #5
sebi1990
thanks guys
Old 08-15-2012, 11:33 PM   #6
Macrackie
Macrackie's Avatar
Drives: 2011 Camaro LS Stripper model
What were your 60 ft times? I cut some 1.9s by launching around 3000 when the light goes green bury the throtlle and slowly let out the clutch as you finish burrying the throttle. Manage the engine speed with clutch slip. Don't make to many pass's like this back to back maybe three tops. After 6 or 7 my clutch fluid got hot and pedel stuck 3/4 released. I could smell clutch for the next two weeks. Our v-6 clutchs are pretty weak. We don't have the torque to just side step the clutch and get that 3900lb car moving like the v-8 guys.
After some practic I am pretty sure I can cut a sub 2 second 60' on the street with out slipping a tire. With what I said above.
Macrackie is offline   Reply With Quote
Old 08-16-2012, 09:52 AM   #7
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
Wow when I read "lunch" I thought you destroyed it
MudderFinger is offline   Reply With Quote
Old 08-16-2012, 10:11 AM   #8
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
I thought we were talking about meeting for lunch lol
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 08-16-2012, 09:54 PM   #9
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
I thought OP meant he took her to lunch.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 08-16-2012, 10:13 PM   #10
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
You're going to have to play with it. The SS guys are giving you info off their experience and they have a lot more torque than we do, so our cars react different. My car, even though it's also an LS, will be different due to my mods and my drag radials. Track prep will also be different and play a roll.
Each time I've gone it'll be a little different. The way Macrackie says he does it has worked but I've also dumped and jabbed the throttle, depending on the track. Even with the drag radials, it still spins the tires a little but it keeps the rpm's up.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
