Cold Air Inductions
Old 07-22-2010, 01:31 PM   #1107
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
GTA:
How much boost are you running? What size pulley? Thanks.
Your car is
Well, It's the stock Maggie pulley so right at 6.5 pounds.. When we added the CAI I actually gained a little boost... So, I'm just under 7 now I think.
Also we've been playing with the mufflers. It was dyno'd with a 3' open muffler that was way too loud.
Then Tom put the 3" chambered muffler on (what I have now) and it should perform the same... maybe better with the increase in back pressure.
After talking to ARH, they want me to put a 2.5" on and I should get a bit better performance...
So my RWHP numbers a a bit of an estimate... Everyone that has worked on my car says I should be over 550 in the winter...
But I'm not quite ready to make that claim without a dyno....
FWIW.
Old 07-22-2010, 01:34 PM   #1108
GTAHVIT
Blessed
GTAHVIT's Avatar
Maybe he sped up the camera and dubbed audio to match? He was really only doing a few miles per hour. Hell, he may have had time to stop the car, walk to the camera, and kick it to appear as if it was the wind.
The only defence I have to that is you've driven my car???
Old 07-22-2010, 01:36 PM   #1109
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Here ya go.
DUDE !!!
Awesome video. It looked like someone kicked the camera at the end.
It's the THR22 "Sonic Boom"
Great video
Old 07-22-2010, 01:39 PM   #1110
GTAHVIT
Blessed
GTAHVIT's Avatar
DUDE !!!
Great video
Thanks man.
Hey when you have a sec. Can you help explain why the mufflers should be necked down to 2.5" and how that helps performance.. Back pressure and scavenging..
Thanks!
Old 07-22-2010, 01:44 PM   #1111
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Oh, ya. Right. And I've yet to start your car without smiling at the sound. lol
Old 07-22-2010, 02:58 PM   #1112
GTAHVIT
Blessed
GTAHVIT's Avatar
GTA:
Your car is
oh and to you and PQ...
My car may be supercharged... But I really need to catch you two in the looks department..
your cars are gorgeous.
Old 07-22-2010, 03:07 PM   #1113
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
Originally Posted by Jekyll-N-Hyde View Post
I like how it moved the Camera when you passed by
sounds good
it wasn't the camera.. the Earth moved.
Old 07-22-2010, 03:17 PM   #1114
GTAHVIT
Blessed
GTAHVIT's Avatar
I heard there was gonna be a new federal law that no more than 15 Camaros can be driven at any one time because of that problem...
Old 07-22-2010, 05:00 PM   #1115
speedster
SST...
speedster's Avatar
Thanks man.
Thanks!
Here:
The exhaust gases leave the cylinders of an automobile engine at a pressure of around 60-80 lb. per sq. in. and with a velocity of up to 150 ft. per sec. This results in a considerable volume of noise, which must be reduced sufficiently to make the vehicle inoffensive to the driver and passengers, and to the public at large. This legal requirement is achieved by allowing the gases to expand into a silencer chamber, where the intermittent and violent discharges of gas are broken up and emerge from the tail pipe as a continuous and relatively uninterrupted stream.
The exhaust note of an internal combustion engine is made up mainly of a low- to medium-frequency band of 50-600 cycles per second, and a high-frequency band of 3000-10,000 cycles per second.
The low-frequency vibrations appear to result from resonance between the varying capacity of the cylinder and the exhaust system as the piston moves through its exhaust stroke, while the high-pitch sound originates in the release of the high-pressure gases through the exhaust ports.
According to experts (I usually check with David Vizard first) you should shoot for around a 0.2 psi backpressure for no HP loss in a system.
In our terms, you are trying to use the exhaust to both control noise and optimize the flow IN THE COLLECTOR AREA. Basically you want the next cylinder in the firing order (on the same bank of a motor like your LS3) to scavenge such that the next cylinder does not have to do the work. For your THR22 items such as cubic inch, stroke, compression, forced induction boost, cam specs, etc. come in to play. Whether you go with 1-
7/8 or 2" primaries, use a 2.5 or 3.0" exhaust, necked down or not, a X-pipe, H-pipe or any other combination is best determined by dyno testing or trial and error. I am sure THR researched this prior to putting your beast together.
Sorry, the long winded version. Yes, you guessed it, I am sitting on a boat in an island cove right now. Getting ready to leave and get some dinner.
Old 07-22-2010, 05:43 PM   #1116
PQ
Booooosted.
PQ's Avatar
Old 07-22-2010, 08:17 PM   #1117
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2014 1LE...Drove: 2012 ZL1
Here ya go.
Did you decide to stick with the chambered mufflers?
...But I really need to catch you two in the looks department..
I think what you're planning will get that done...patience...
"Keep the faith." - - Read Twice Before You Post.
Old 07-22-2010, 08:25 PM   #1118
GTAHVIT
Blessed
GTAHVIT's Avatar
I'd like to try the 2.5" just to see the difference.
Old 07-22-2010, 08:29 PM   #1119
Mr. Wyndham
Yeah -- it's probably worth a try. But consider that Doug's car about made my ears bleed when he first arrived at the hotel...
That's a healthy growl you've got there, and I thought maybe you switched them. hehehe...I remember when I made some noise for your kids, Billy got all silent and said, "Now that sounded beautiful."
Old 07-22-2010, 08:31 PM   #1120
GTAHVIT
Blessed
GTAHVIT's Avatar
Yeah I'm pretty happy with it.
gta has no internets, gta needs glasses, is there a car here?, mrs. gtahvit > gtahvit, they stay on the mantle, weak car needs more power
All order status requests in here (up to status 3800). List of Order Status Codes. GTAHVIT Camaro Price | Ordering | Tracking | Dealers Discussions 54436 12-28-2016 09:04 AM
Build from Scratch The_Blur Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 18 04-23-2010 10:39 PM
Missing "Ladies of Camaro 5" thread comment.... Silverado Off-topic Discussions 2 10-08-2009 01:23 PM
Why An april build is just as good as a March build Sean_W Camaro Price | Ordering | Tracking | Dealers Discussions 10 02-07-2009 03:51 PM
