BeckyD@RodgersChevrolet
Old 08-09-2012, 03:34 PM   #1
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Lighting advice needed...
So after spending last weekend at the Fest and seeing all the amazing cars and lighting configurations I have decided my car needs a little attention in that department. I don't want to go crazy with it, but so far I have swapped all the stock lights to LEDs, including adding the Technostalgia taillights.
One of my favortie lighting mods I saw at the Fest was the grill lights with a controller that made it look like the car was breathing. My car is AGM and is completely blacked out with some red accents, so I am thinking about going with red grill lighting. But, I can't help but think that I may want to change the colors at some point, so maybe the RGB lighting would be better for me.
My question is: should I go with the RGB, and if I do which controller(s) would I need to make it "breathe"? Would I need a separate controller for RGB and patterns?
I looked at AAC's website, and it looks like I might possibly need the RGB controller and the multifunction controller. Fron what I can tell, if I only went with a single color LED strip, I would just need the multifunction controller.
I don't really know much about show lights, so any advice you can give would be appreciated. I also know that at some point I am will probably want to probably add more lights, so keep that in mind when giving input.
Thanks in advance!
Deke736 is offline   Reply With Quote
aac, breathing, controllers, lighting, lighting tips
