BeckyD@RodgersChevrolet
Old 08-11-2012, 11:33 AM   #1
BumbleBeeSS2009
BumbleBeeSS2009's Avatar
Drives: Rally Yellow 2SS/RS
HELP! with some DRs
So I posted this in the wheel/tire section but I think this may be a better place for this...
I found a good deal on some 18" Vette GS wheels (they fit) and I found a set of used NT555Rs on Craigslist for ($50 - yes for both) but they were 285/35/18 which only gives me a 26" tall rear tire... I was hoping the shorter tire would improve my gear ratio (A6) for when I go to the track...
However.....
I had them put on, (I didnt have them put in TPMS sensors cause I didn't think I needed them for just the track) I drove around for a little but after about 5 minutes shit went all haywire... all 3 of my traction lights lit up, my ABS light and brake light came on and service stabili trac popped up on the DIC - and the car felt like it lost all power... but after about 3 seconds the car came back to life but all the lights were all still on...
I shut the car off, let it sit for a couple minutes and then started it up again... after about 5 minutes the same thing happened again....
Thing is the car seemed perfectly driveable after this happened but it seemed to happen every time I started it and drove for a couple minutes...
I understand that the computer was thrown all out of wack since the fronts are 275/40/20s and they were spinning at different rates...
but since this happens everytime I shut the car down and start it up I would basically never be able to shut the car off at the track, or start it up,drive around until it happens and then go sit in the staging lanes while idling....
Should I just say F*ck it and scrap the tires and get a tire closer to the OD of the stocks?
Also whats the lowest OD I can go without shit getting all crazy on me? I was thinking 275/45/18s - they'll be 1" shorter (27.7")
Any info would be much appreciated....
#52325 Delivered 11/07/2009
BumbleBeeSS2009 is offline   Reply With Quote
Old 08-11-2012, 02:03 PM   #2
BumbleBeeSS2009
no one?
Old 08-11-2012, 03:18 PM   #3
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
*I edited my original response* unsure now about my previous numbers.
You can either put 26" tires in front to match or get the 28" tire put back on the rear. Or you can just live with not having ABS or Stabiltrack, not very safe on the street if you ask me.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 08-11-2012, 03:40 PM   #4
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Dump the tires and get the right size. Problem solved.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 08-11-2012, 04:32 PM   #5
BumbleBeeSS2009
Thats what I figured.... Oh well at least the tires were only $50. ...
Old 08-12-2012, 09:33 AM   #6
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
also the nitto 555 suck for track...you need the nitto nto5 dr,s if you want a sticky tire and real dr.....the 555,s aren,t much better then the pzero
mikepage0007 is offline   Reply With Quote
Old 08-12-2012, 11:00 AM   #7
Texas2SS
Vroom
Texas2SS's Avatar
Drives: Rarely
I ran with a 305/35/18 Mickey Thompson and never set off any lights (besides not having TPMS). A friend borrowed them and had the same thing happen that you specified, all lights came on the dash. I guess some cars are just more sensitive then others.
LSX, Boost, 9", TH400
xxxxhp - xxxtrq
Texas2SS is offline   Reply With Quote
Old 08-12-2012, 12:13 PM   #8
mikepage0007
Drives: 2010 camaro
tony, did you hold down the stab button for 7 sec,s to turn everything off b4 running
Old 08-12-2012, 07:06 PM   #9
BumbleBeeSS2009
Once all the lights popped up the button didnt do anything.. guess I can try holding it down before the lights come on....
