Old 08-11-2012, 02:52 PM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
CEL came on 2 days after long tube/mid pipe install...
So whats causing it? The mid pipes and LT's have the respective sensors hooked up to them. Would it be the LT's at all since they have been installed for 2 days and just now the light came on?
Also, engine oil life is at 20%....which will be changed tomorrow. Could this be it?
Cornflakes'Camaro is offline   Reply With Quote
Old 08-11-2012, 03:15 PM   #2
SS King
SS King's Avatar
Drives: a Panty Dropper
Need to tune the rear o2 sensors out or you'll keep getting a CEL
SS King is offline   Reply With Quote
Old 08-11-2012, 07:35 PM   #3
blufin
blufin's Avatar
Drives: Fire Engine
Since the rear o2 sensors were moved further down the exhaust line, they exhaust that reaches them is cooler than it should be, so the sensor picks up on this and throws a code. If the rear sensor catches this, it thinks the cat isn't doing its job. Have it cleared, problem solved.
No, it isn't your oil indicator.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 08-11-2012, 10:15 PM   #4
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
this is pretty much normal... have to get them tuned out, though some companies will say you won't throw codes, its always a risk when you modify the cats/headers in any way... and when you run longtubes and no cats like me, you throw codes 30 miles later, lol... but I had them tuned out
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
Old 08-12-2012, 06:39 PM   #5
Cornflakes'Camaro
Thanks guys! I will be hitting up a dyno guy around upper marlboro here in MD soon. I was beginnin to worry!
Old 08-14-2012, 02:28 PM   #6
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
I'm having the same issue. If I get it tuned out will that cause me to fail an emissions test?
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 08-14-2012, 03:40 PM   #7
Neumatic
Neumatic's Avatar
Drives: 2010 Camaro 2SS M6
No, if you fail an emissions test it's not because you tuned out the CEL, it's because of the headers themselves.
Neumatic is offline   Reply With Quote
Old 08-14-2012, 05:38 PM   #8
Blk-Ice
Blk-Ice's Avatar
I had a tech at Autozone tell me that if I delete my 02 sensor code too many times it will "Red Flag" it in my system.....is this true?
Old 08-14-2012, 06:06 PM   #9
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
See my thread here, good info on the subject:
http://www.camaro5.com/forums/showthread.php?t=242806
Bye bye, Bumblebee!
Old 08-15-2012, 09:19 AM   #10
Blk-Ice
Blk-Ice's Avatar
Man, that was a helluva read....lots of great info!
Old 08-15-2012, 04:26 PM   #11
strych9
Gone Euro!
strych9's Avatar
Bye bye, Bumblebee!
Old 08-15-2012, 08:32 PM   #12
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
it's the front sensors that are moved back and don't heat and switch properly.
the rears ones throw a code because aftermarket cats are not as good at cleaning the exhaust as factory cats but they flow more.
Higgs Boson is offline   Reply With Quote
Old 08-16-2012, 12:40 PM   #13
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
You will need a JRE custom tune to correct that via the SCT hand held Tuner and email all available from JRE.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
