Old 08-11-2012, 03:21 PM   #1
45th in Georgia
45th in Georgia's Avatar
Drives: 2012 45th Anniversary RS
MRT v2.0 exhaust questions for those who have it.
Did you weld yours on or use the clamps that came with them ? Is there an advantage to doing one or the other ? Difference in sound ? Thanks !
45th in Georgia is offline   Reply With Quote
Old 08-11-2012, 03:45 PM   #2
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
I would guess a weld on job would always be the go-to route. Clamps have at least some chance of failing and that weld isn't going anywhere.
I don't see sound being a problem unless you didn't have them clmaped properly.
If possible I'd go with welding them on.
awfarley is offline   Reply With Quote
Old 08-11-2012, 08:20 PM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
We've got about 4k miles with ours clamped so far so good no issues
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 08-11-2012, 08:28 PM   #4
MistyBlu10
GOBLIN
Drives: 2015 SS Convertable Green Flash
on the SLP Loudmouth i had on my 10 V6 i clamped it and all kinds of carbon leaks all over the place black soot everywhere so ima get the ARK cat back and get it welded this time
2015 2SS Green Flash Edition
2012 Camaro LFX 45th born 9/24/11 sold 4/1/15
2013 Equinox LTZ
2013 Cruze LTZ
2010 LT2 BLUE RS CAMARO TRADED FOR 45TH
2011 COLARADO Z71 TRADED FOR MALABU
2011 MALABU LTZ TRADED FOR BLUE CAMARO
2007 Z71 Avalanche LTZ
1987 K5 Blazer
BOWTIES AS BLOOD CELLS
GM RULES
MistyBlu10 is offline   Reply With Quote
Old 08-11-2012, 09:03 PM   #5
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Clamped correctly their should be no leaks or whatever 2000 on mine, it just keeps sounding better
Lil' Nasty is offline   Reply With Quote
Old 08-11-2012, 11:17 PM   #6
06_warrior
06_warrior's Avatar
Drives: 2012 1SS LS3 M6 black on black :)
Clamped mine. Just traded my 2012 or a 2012 1SS and stripped the car back to stock. Was so easy with the clamps. If it was welded i probably would of traded the car with the expensive exhaust on the car. :(
06_warrior is offline   Reply With Quote
Old 08-12-2012, 11:45 AM   #7
GTFD2
GTFD2's Avatar
Drives: C7 2LT Vert 2014/2LT RS 2012
Clamped mine. Had an issue with one not getting tight enough and it kept moving on the exhaust pipe. Took out the spacer and all is good.
GTFD2 is offline   Reply With Quote
Old 08-18-2012, 01:34 PM   #8
toyboy1980
toyboy1980's Avatar
Drives: 2012 45th 2LT/RS
Like others have said, clamps have the opportunity to loosen over time, leak, etc. Weld for the win.
Mods: RX Catch Can / MRT Version 2.0 Exhaust / RotoFab CAI / Apex Motorsports Scoop + Windshield Washer Bottle Relocation / Hurst "HardDrive" Plate / Mud Guards / Heritage Grill + Street Scene Lower Valance / Metra Kit + Pioneer AVIC Z120BT / AAC "Ghosted" LED Concept Side Markers / P13W Plasma LED Bulbs + DRL Harness
toyboy1980 is offline   Reply With Quote
Old 08-18-2012, 05:04 PM   #9
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I always weld my exhaust but I can't give you a legitimate reason why. I just do.
Old 08-18-2012, 05:11 PM   #10
Bradrulz
Drives: 2011 Camaro 1LT IOM
Mine is welded
Bradrulz is offline   Reply With Quote
Old 08-18-2012, 05:18 PM   #11
wadew2lt
U.S. Army Veteran
wadew2lt's Avatar
Drives: 2LT/RS SGM M6 Polished 20's
Clamped and not a bit sorry. Works great. It also allowed me to align them the way I wanted them. Once they're welded, they're there to stay, obviously.
I suggest clamping yours first. If you later find you want them welded...
wadew2lt is offline   Reply With Quote
Old 08-19-2012, 01:48 PM   #12
45th in Georgia
got it welded on......the guy took the time and made sure the tips were perfectly centered. I really appreciate all the replies.
Old 08-20-2012, 03:53 AM   #13
jbrewer.m
jbrewer.m's Avatar
Drives: 2012 Chevrolet Camaro 2LT TF3
Same here
jbrewer.m is offline   Reply With Quote
Old 08-20-2012, 10:11 AM   #14
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Mine is clamped on. Didn't want to pay for the weld and wanted to make sure I liked it before I made it permanent. Just never had it welded.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
