Old 08-12-2012, 06:46 AM   #1
Bu3ali
Bu3ali's Avatar
Drives: Camaro LS3/RS, Cadillac CTS
Fuel x Tune question
What happens if I changed the fuel I tuned for ?..
i.e if I was on a road trip and I only had the option of going to a lower fuel grade ?
Thanks !
10' LS3/RS CGM .. ARH LT's, Corsa Cat-back, Vararam intake, Dyno tune, Matte Black stripes + Bowtie + Vent inserts.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=38228&dateline=134383  0129
Bu3ali is offline   Reply With Quote
Old 08-12-2012, 11:12 AM   #2
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Are you Tuned for 93 and thinking you may have to put 91 in? Are you NA or FI?
Sent from my iPhone using Tapatalk. If is spelllled wrong deal with it.
Crime2 is offline   Reply With Quote
Old 08-12-2012, 11:22 AM   #3
Supercharged SS
Drives: 2010 Camaro
If you don't beat the car you will be fine. I could fill my car with 87 and cruise it around town if I really wanted to.
Old 08-12-2012, 02:21 PM   #4
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
yep just don't apply too much cylinder pressure. as long as your timing is not too high at part throttle.
Higgs Boson is offline   Reply With Quote
Old 08-13-2012, 04:23 AM   #5
LVDran
LVDran's Avatar
Drives: 2010 V6
Just to be safe you may want to pull your fuses whenever you get back home and you are able to use the octane fuel you usually do. Just in case it messes with the LTFTs. I wouldn't think it would after just a tank or two if you have had the car for awhile. But better safe than sorry.
LVDran is offline   Reply With Quote
Old 08-13-2012, 06:45 AM   #6
Bu3ali
Bu3ali's Avatar
exactly .. tuned for 93 and will have to top up 91 if i wanted to to this road trip thing because not all stations will have 93 !
The car is NA !
Old 08-13-2012, 06:45 AM   #7
Bu3ali
Bu3ali's Avatar
As in no full throttle ? or not high speed ?
Old 08-13-2012, 06:47 AM   #8
Bu3ali
Bu3ali's Avatar
Yeah .. I dont want to risk it .. but if there is a possible safe way to do it then why not !
Old 08-13-2012, 10:01 AM   #9
Redline Motorsports
Redline Motorsports's Avatar
Drives: Several...
Exactly....
However if you do get enough knock sensed, and your calibrator left your low octane table stock, you could drive the car on good fuel with less then optimal spark.
May have the reset ECM or drive it a bit to relearn back to the HO table.
Howard
Redline Motorsports is offline   Reply With Quote
