Caryle Racing
Old 08-12-2012, 02:26 PM   #1
sneakyworm
sneakyworm's Avatar
Drives: 2014 1LE
Wheel hop
So yesterday I went to the track, been there many times. I had an issue I've not had before. My car makes 476/435 at the tires. The problem was wheel hop. Not on the launch but after the 1-2 shift. It got bad enough that I had to lift a little. It's never happened before. The only suspension mod is 1 inch lowering springs. Running nitto nt05 315 wide tires. Set up is unchanged for a year now. Any thoughts?
sneakyworm is offline   Reply With Quote
Old 08-12-2012, 02:34 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
"Wheel Hop" is very simply a rapid and repeated loss and recovery of traction. When a car begins to accelerate various bushings and suspension/chassis components deflect. Under normal driving conditions this flexing is negligible but when the car is launched aggressively the deflection causes significant toe and camber changes which reduce the contact patch of the rear tires. This leads to a reduction in traction and momentary wheel slippage which alleviates the toe and camber changes and allows the rear tires to regrip. The vicious circle then continues as the suddenly improved traction again results in deflection leading to wheel slippage.
Getting rid of wheel hop is typically pretty straight forward. It is all about eliminating flex and thus limiting the movement of the rear tires in relation to the chassis under acceleration. The main culprits to blame for all the flexing are:
Rear trailing arms and their bushings
Toe rods and their bushings
Sub frame, differential, and control arm bushings
Upgrading those items will take care of wheel hop in most instances and dramatically improve traction and control under aggressive acceleration.
Old 08-12-2012, 02:47 PM   #3
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Nice Apex! I would also add, from experience, a very good alignment is key to zero wheel hop also.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 08-12-2012, 02:48 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Back in the 4th gen days we'd do lower control arms because the stock bushings were too spongy and would let the rearend travel up and down.
I don't have a feel for the 5th gens I'll have to hang out with Alan from BMR at the next race and let him explain it all to me.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-12-2012, 02:54 PM   #5
sneakyworm
sneakyworm's Avatar
Drives: 2014 1LE
Thanks apex chase. I knew what wheel hop was but was curious as to why now. I've probably got 250 or more passes with it. The only change to the car was a cam which added a lot of power, but I have been to the track 3 times since then and before last night. Btw what part of Louisville are you in, I drive through there twice a day mon-fri.
Old 08-12-2012, 03:01 PM   #6
Apex Motorsports
Thanks. Proper alignment is also very important.
That would be hard to nail down. The specific root cause could be any number of things but it boils do to there being more deflection than there has been in the past. We are just east of Louisville in Shelbyville.
Old 08-12-2012, 03:02 PM   #7
Pro Stock John
Writer
I'd probably start with the lower control arms, the bushings are probably getting beat up from all your launches. If you had not run DR's before, it will make it worse.
PROJECT HEAVY CHEVY
Old 08-12-2012, 03:14 PM   #8
sneakyworm
sneakyworm's Avatar
Drives: 2014 1LE
Trailing arms and toe arms and bushings along with a diff brace are on the list for my next round of mods. Im going to have a gear installed so that seems like the time to do the suspension. The nittos are the street tires not the dr. I'm waiting for sticky tires until after I strengthen the rear end.
Old 08-12-2012, 08:58 PM   #9
Synner
Drives: not stock
Your alignment may have changed which can cause more wheel hop. Cradle bushes cured mine and I did trailing arms later as well.
Old 08-13-2012, 10:29 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Hey Sneakyworm, Chase @ Apex hit it perfectly. If there is anyway we can help you out here at BMR Suspension let us know.
Kyle
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 08-18-2012, 12:40 AM   #11
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Yes I have all that stuff Apex mentioned but no wheel alignment yet, I do still have some wheel hop. But not all the time.
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 08-18-2012, 06:56 AM   #12
Apex Motorsports
Thank you sir.
Old 08-18-2012, 07:12 AM   #13
Chevrole+
Chevrole+'s Avatar
Drives: 2010 Camaro 2LT
Chevrole+ is offline   Reply With Quote
Old 08-18-2012, 10:31 AM   #14
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
Hey Apex do you guys do installs also? How hard are trailing arms and Toe Rods to install?
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
