Emblempros
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Motorsports Discussions
View Poll Results: Hoosier A6 or Hankook Z214 tires for Auto-X events
Hoosier A6 7 63.64%
Hankook Z214 1 9.09%
Other 3 27.27%
Voters: 11. You may not vote on this poll
Old 08-12-2012, 03:19 PM   #1
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
Hoosier A6 or Hankook Z214 for Auto-X events
Looking for tires for my 2010 Camaro and Iím wondering if the huge price difference between the Hoosiers and Hankook tires is worth it?
In order for me to go to these tires, I have to purchase a new set of wheels since the donít make a good competition tire for the stock 20x9Ē wheels that come with the Camaro.
Iím going with an 18x9.5 wheel and will either be going with a 275 or 285 since I have major clearance issues with the design of my aftermarket PHADT coilovers and their reverse design.
My car weighs in just over 4200lbs without me in it and has a horrible under steer problem putting over 500hp at the rear wheels.
I typically run OSP, can I still run that class with the tire and wheel combination Iím looking at?
Trying to get this setup in time for the American Auto-X Series Larry Park Memorial events in Marina California in late September.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 08-17-2012, 08:10 PM   #2
Atlas
Would you kindly...
Atlas's Avatar
Drives: Destitute
Think I remember talking with you at the last August event, I had the SIM LT Camaro running GS It was great meeting ya, thanks for the course tips! As for your tire situation, I can't really help ya there, but I've seen a majority of the SCCA Fresno Chapter vette guys along with others are running Hoosier A6 at the last event. Their cars stuck pretty good on otherwise stock suspension. Think we hit a course temp at around 110įF that day. I think Gary Mac runs those on his Z06.
Atlas is offline   Reply With Quote
Old 08-22-2012, 11:01 PM   #3
JMAC2011
MONGOOSE
JMAC2011's Avatar
Drives: 2011 SS Camaro M6
Looking for tires for my 2010 Camaro and I’m wondering if the huge price difference between the Hoosiers and Hankook tires is worth it?
In order for me to go to these tires, I have to purchase a new set of wheels since the don’t make a good competition tire for the stock 20x9” wheels that come with the Camaro.
I’m going with an 18x9.5 wheel and will either be going with a 275 or 285 since I have major clearance issues with the design of my aftermarket PHADT coilovers and their reverse design.
I typically run OSP, can I still run that class with the tire and wheel combination I’m looking at?
Just an option for you.... I run factory 20x9's with Toyo R888 - 285/35/20's on all 4 corners. I have Pfadt coilovers and camber plates. 5mm spacers help ensure adequate clearance. My front camber is 2.1 degrees. Tires are awesome. I've pulled 1.5 g's at Road Atlanta in turn 10a and I can pull a consistent 1.3g's everywhere else. Plenty of Smarty Cam video to proove it! I'm still not happy with the overall combination either... simply because I know I can go to an afertermarket 18" or 19" and go with a 10" wheel and 295's all around (even with the Pfadt setup). This will allow me to drop 11 - 12 pounds per wheel / tire combo. Roughly 45lbs of unsprung weight or a perceived 900lbs of centrifugally rotating mass ("estimated" 1lb of unsprung is comparable to 20lbs at speed). Maybe over exagerated but still exciting based on what I read.
_________________________________
MODS: 470 RWHP / 447 RWTQ
Lethal Racing Night Fury 231/242 113-111, C5R chain, dbl springs, Comp pushrods.
ARH 1-7/8" Headers and complete exhaust - NO cats!
Varraram CAI - Vmax throttle body, ATI 10% underdrive pulley
RPS Street Twin - MGW Shifter
3.91 gears + DSS 1000hp axles
PFADT - Stage 4 Camaro Road Racing Kit - 8" springs 325# and 600# - ZL Spec Sway bars - Strut Tower Brace - Camber plates.
CTSV front calipers - Hawk DTC 30 pads
Street: Forgestar F14 20x9 and 20x11, 275/315 Nitto Invo's, Track: TOYO R888 285/35/20 on 4 corners
JMAC2011 is offline   Reply With Quote
Old 08-23-2012, 10:29 AM   #4
Doubleblank
Doubleblank's Avatar
Drives: 2010 Camaro SS, 2014 Z28
My suggestion is to discuss your setup with whoever is making your wheels for you. If you're going to have 18inch wheels made up, let them tell you how much tire you can run with your suspension as installed, any spacers needed, etc. I was going to run a square setup (in order to rotate tires, etc). But after talking to several track guys running big, staggered setups, that is how I went.
In summary, find a good wheel/tire company that knows autoX and road tracking and let them guide you thru your choices. You could then bounce their recommendations off of the forum here too.
ERL 500 ci Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, MGW Shifter, StopTech BBK, Pfadt C/O's, Pfadt ASB's, etc, PowerFab Dynotune
Doubleblank is offline   Reply With Quote
Old 08-23-2012, 09:28 PM   #5
JMAC2011
MONGOOSE
JMAC2011's Avatar
I agree with Doubletrouble above. Don't be afraid to talk to Nineball. I think he has the market cornered on the 5th gen as far as knowledge of wheels / offsets. He will point you in the right direction. There are plent of other knowledgable professionals the site as well such as Eric at Torq. Eric is quite familiar with the Pfadt specific setup.
Old 08-30-2012, 12:38 AM   #6
Silver2SSRS6spd
Prefer to be blown!
I ordered the Hankook Z214's in a 275\35-18 and 18" wheels that match my 20" wheels so I shouldn't have any issues unless the ~1" difference in where the tire is rubs on the PHADT coil overs where I will have to use spacers. I pick them up tomorrow and will install and heat cycle them this weekend. Thanks to all those that provided input, I will update all late next moth after the big auto-x events.
Old 09-05-2012, 11:33 AM   #7
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
In these two tire companies make the 18" tire ?
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 09-06-2012, 01:56 AM   #8
Silver2SSRS6spd
Prefer to be blown!
Hankook and Hoosier make 18" tires and Hoosier also makes the A6 in 19" sizes.
Old 09-10-2012, 01:32 PM   #9
woodside783
Casey Woodside
Ok thanks
Old 09-15-2012, 05:27 PM   #10
Silver2SSRS6spd
Prefer to be blown!
Bad news for me today, the 18" wheels that I purchased so I can run the Hankook tires do not clear the rear brake calipers. It's either grinder time to time to look for a different wheel that will clear the calipers.
Old 09-18-2012, 02:57 PM   #11
woodside783
Casey Woodside
Grind or just get some new pads. i went with new pads it is a easy install
Old 09-18-2012, 07:25 PM   #12
Silver2SSRS6spd
Prefer to be blown!
The pads don't rub, it's the brake calipers that hold the pads. I hit them with the grinder this morning and all is fine.
Steve
Old 09-18-2012, 09:30 PM   #13
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Steve
Pics? I'd like to see how close the clearances are.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 09-20-2012, 11:34 PM   #14
Silver2SSRS6spd
Prefer to be blown!
I will post pictures as soon as I get a chance. I had to order some longer wheel studs today and the only ones that I could find were made by PHADT for $165 for 10 of them. I did not opt for the lug nuts for an extra $90.
