HURST
Old 08-13-2012, 01:21 AM   #1
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
DIY leather stitching!
So I started my first modification the other day! I decided to dye the leather stitching from white to blue! After seeing a few other threads from people who had done it before, I decided that it seemed easy enough, and that I would give it a shot. It was super easy, but extremely time consuming and tedious. I started doing mine on August 9th, and I finished on August 11th, it probably took me a total of 7.5 hours (and about 2-3 of those hours was with the help of my sister). It probably took me longer, because I wanted it to look perfect, but no matter what, this is a time consuming DIY.
I bought blue fabric dye pens, and they worked great! They dyed the stitching perfect, but they didn't dye the fabric at all, so the pens where perfect. to do this all you do is buy fabric dye pens (I've heard of people doing this with paint, but I thought that was too risky). Then make sure you have paper towels or wash cloths on hand, and then you draw over the stitching small sections at a time, then you wipe off the excess ink off the leather. Getting ink on the leather is almost inevitable, but as long as you wipe it off it will be fine. You just do this section by section and after a while it will be finished! After I was done, I went through and cleaned my seats with leather cleaner, and the ink stayed on fine! But here are some pictures of my car after I dyed the stitching!
Aubrey64 is offline   Reply With Quote
Old 08-13-2012, 01:31 AM   #2
Aubrey64
Aubrey64's Avatar
Some more pictures (for some reason I wasn't able to upload them all at once)
Old 08-13-2012, 03:12 AM   #3
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/2012 SS
Looks really good! I did my SS on the head rests awhile ago but never pusted up pic's so here is some to maybe help others get some ideas
B4
After
2012InfernoSS is offline   Reply With Quote
Old 08-13-2012, 03:28 AM   #4
Aubrey64
Aubrey64's Avatar
B4
After
Looks Great!
Old 08-13-2012, 10:36 AM   #5
Vengeance Graphix
Vengeance Graphix's Avatar
Drives: Wrapped 2010 2SS
that came out great, i might do this to mine now lol
what store did you get your fabric pens from? im guessing like a Michaels arts and crafts maybe?
Old 08-13-2012, 10:50 AM   #6
20121lt
20121lt's Avatar
Drives: 1LE SS/RS 2013
looks good very good
20121lt is offline   Reply With Quote
Old 08-13-2012, 11:55 AM   #7
Aubrey64
Aubrey64's Avatar
Yeah, michaels will most likely have them. I got mine from hobby lobby, which is a store very similar to michaels, and they where about $7 for 3 pens
Old 08-13-2012, 01:41 PM   #8
babytiger
it's hers...
babytiger's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
Looks good. Definitely catches the eye...
babytiger is offline   Reply With Quote
Old 08-13-2012, 01:46 PM   #9
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I wonder if black stitching can be dyed the stone/white color in the black interior Camaro's ??
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 08-13-2012, 04:04 PM   #10
Aubrey64
Aubrey64's Avatar
Ed M.
I am not sure. You could always try it on a very small section in a place that isn't very visible on your car to see if it works.
Old 08-13-2012, 10:48 PM   #11
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
I'm curious how these will hold up in years to come, especially if the car sits in the sun... I'd be afraid to do it to mine.
joeybsyc is offline   Reply With Quote
Old 08-13-2012, 11:01 PM   #12
Aubrey64
Aubrey64's Avatar
Yeah I am curious too. Mine sits in the sun (unfortunately my dads car has dibs on the garage). I got my LT used and so the interior isn't like new and so I would like to replace the leather seats in the next 3-5 years anyways and so I thought that I had nothing to lose since I want to eventually replace them. But based on what i have seen from other Camaro owners, I think all I have to worry about is some fading, and that isn't an issue since I can always reapply
camaro, diy, dye, leather stitching
