SDTW Custom Wheels & Tires
Old 08-13-2012, 11:36 AM   #1
Mike535
iRacing Pro
Mike535's Avatar
Drives: Camaro ZL1 Summit
ZL1 Gas Pump ???
Will the ZL1 Gas Pump will support this Setup ??
ARH Headers 1 7/8
High flow cats
ID850 injectors
N.W TB 102 mm
New Era CAI
160 Degree Thermostat
2.55" Upper Pulley
Solid isolator
Lapping Sanair Lapping Mosport
Race the Runway 248km/h
1 7/8'' ARH Headers & High Flow Cats
63 lb Fuel Injectors - 160 Degree Thermostat
Supercharger Isolator Coupling
2.55'' 8 Rib 10 Bolt Pulley - Kenne Bell Boost a Pump
8 Rib Poly V Belt For 10% Overdrive Pulley & 2.55'' Upper Pulley
Overdrive Harmonic Balancer Kit
10% Overdrive Balancer Pulley
10 bolt Supercharger Pulley Hub
Nick Williams 102mm Throttle Body
New Era CAI with w/w reservoir
Port and polish supercharger snout
Snow Water Meth
680 RWHP.....!
Mike535 is offline   Reply With Quote
Old 08-13-2012, 11:42 AM   #2
Supermaro585HP
Drives: 2011 Camaro SS RS
Not sure!!! I was told it will handle up to 650HP at the crank. I saw a post on here saying they had there build up over a 700HP and it was fine.. Good luck and I'm interested to see what this thread will say.
Supermaro585HP is offline   Reply With Quote
Old 08-13-2012, 01:31 PM   #3
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
You will be right on the edge.....we offer a boost-a-pump for this setup and require it with our packages
Meister@Torq is offline   Reply With Quote
Old 08-14-2012, 11:59 AM   #4
Mike535
iRacing Pro
Mike535's Avatar
So with a Boost a Pump i should be ok for this package ?
Snow Water Meth
680 RWHP.....!
