Flowmaster Exhaust
Old 08-13-2012, 04:52 PM   #1
Synister
Drives: Summit White RS Vert
RX Catch Can question
After reading up on the benefits of installing a catch can, I'd say it's a slam dunk. However I don't see many comments on the benefits of the 2 check valve vs single check valve options. Nor do I see any comments on the benefits of an oil filler cap fitted with a breather.
Would anyone care to shed some light on the subject? Clearly the base line catch can is better than none at all, but would I see any added benefit from having another check valve and a breather cap?
Any insight and / or wisdom is appreciated!
Synister is offline   Reply With Quote
Old 08-13-2012, 05:08 PM   #2
brandonrr
LFX is not the average V6
brandonrr's Avatar
Drives: 2011 Mustang GT 5.0
the 2 check valve catch can is more geared towards FI, meaning a supercharger or turbo(s). if there's any possibility you are going to give your car some boost in the future, get the 2 check valve can. otherwise, the single check is fine.
White 2011 Mustang 5.0 - 4/13/13--current
Silver Ice Metallic 2012 Camaro 1LT - 7/27/12--4/13/13 - traded in for mustang
Victory Red 2012 Camaro 1LS - 3/27/12 - 7/10/12--totaled
POS 2011 Mazda 3 - traded in for camaro
2001 Ford F-150 - traded in for mazda
brandonrr is offline   Reply With Quote
Old 08-13-2012, 05:14 PM   #3
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
As Tracy of RX told me the 2 check valve can is for forced induction such as turbocharged or supercharged engines. He told me the breather is optional and probably will not be needed on non modded engines, so if you plan on modding I would get a breather, if your looking into Forced induction get the double check valve can AND the breather.
The Bird is the word!
Old 08-13-2012, 05:17 PM   #4
Synister
The only engine mods I'm planning on, besides the catch can, are a CAI and maybe axel-back exhaust upgrade. Think the breather would be of benefit?
Old 08-13-2012, 05:26 PM   #5
Angrybird 12
Well I know many times once you get the mod bug it usually dosen't stop with two mods, they aren't that expensive so I would get one "just In case"
Old 08-13-2012, 06:01 PM   #6
Henry G.
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC
Thats all I was going to do now I'm planning on the VMAX TB too
Henry G. is offline   Reply With Quote
Old 08-13-2012, 07:39 PM   #7
Bradrulz
Drives: 2011 Camaro 1LT IOM
Got my RX catch can today. Think they sent the incorrect mouthing bracket. All v6 2010-2011 installs I have seen are mounted on the radiator shroud. The bracket they sent is much to short to provide length needed.
Bradrulz is offline   Reply With Quote
Old 08-13-2012, 08:07 PM   #8
Angrybird 12
The 2012 radiator shroud is different so you need an alternate location, maybe they changed it in 2011 sometime. Look at this thread on post 22 there is a picture of an alternate location. My location pictures are in post 27.
http://www.camaro5.com/forums/showth...=241547&page=2
Old 08-13-2012, 08:07 PM   #9
tjbtexas
tjbtexas's Avatar
Drives: 2012 Camaro 45th Anv. v6 vert
Bradrulz,
i mounted mine to the nut side of the engine cover pin on the passenger side, try that
Mods:CAI,RxCatchCan,Ported TB,Solo-CatBck,Razzi, Technostalgia tail lights,Prado wheels,Escort 9500ci w/ DashTronix HUD projector,AVIC -z140,Scosche,JL Audio Sub/Amp/Spkrs
tjbtexas is offline   Reply With Quote
Old 08-13-2012, 08:38 PM   #10
Bradrulz
That's what I ended up doing. Think it would look cleaner install mounting it on the radiator shroud though. Can only have one screw holding the can on this way as it has to be low enough for engine cover to snap in.
Originally Posted by tjbtexas View Post
Bradrulz,
Old 08-13-2012, 08:46 PM   #11
Angrybird 12
I modified my cover by putting a notch in it to clear the fittings so I could use both bolts to hold the can to the bracket.
Old 08-14-2012, 10:06 AM   #12
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
For a lightly modified street car it isn't really needed but it doesn't hurt either.
Old 08-14-2012, 01:41 PM   #13
tjbtexas
tjbtexas's Avatar
Angry Bird,
me too. I put a notch in the cover
Old 08-14-2012, 02:15 PM   #14
Angrybird 12
Angry Bird,
I went and got my oil changed today and talked to the service rep about carbon build up on the V6 Camaros, he said they have only had a couple that turned out to be from bad valve seals. I have started a pole to see how bad this issue is with the v6 Camaros, since we now have many that are approaching 4 years in service there should be a good indication if there is a wide spread problem or some are crying wolf.
