08-13-2012, 10:12 PM | #1 |
Carbon Fiber Dash Mod
So here's my first crack at writing a thread. I am planning to do some carbon fiber overlay work in my Camaro. What I want to do is no just to wrap a carbon fiber vinyl over some of my dash pieces, but to use REAL carbon fiber and resin, molding it over some of my interior pieces. Then lacquering it and finally using a high solids automotive clear coat to give it that deep gloss look we have all come to know and love with carbon fiber.
Here are a few questions I have as I start with these modifications. First: I am thinking of use two types of carbon fiber's. I don't know yet which two. The first will be the standard 2X2 twill weave that everybody thinks of when we think about carbon fiber. The second type (which I am unsure of) is weather to use a colored carbon fabric (in the 2X2 weave) or to use a 8 harness satin weave. I know that I may be speaking another language when talking about these different weaves so I will post some pictures. My second question is once I choose which style or color of carbon, which areas should I do with those contrasting carbons. Additionally, throughout this thread I will be posting my progress of the wrapping as well as the removal and re-installation of the dash pieces. Alright, here are some photos of what I am talking about. The first picture is of the standard 2X2 twill. The weave pattern is characterized by a diagonal rib created by one warp yarn floating over at least two filling yarns. The second is of what is called 8 harness satin weave. In this weave pattern there is a seven by one interfacing where a filling yarn floats over seven warp yarns and under one. Next are the colors. My car I Silver Ice Metallic, so I am thinking of using a silver, grey or white colored material. I have added some other colored cloths for additional ideas though. Finally is my interior. The door side panels and matching dash trim is one of the areas I am planning to do the carbon overlay. I am also planning on doing my steeling wheel insert and the gauge surround. Now here is where I am unsure. I want to remove the leather on the dash and do that part in carbon fiber, but with a contrasting pattern or color to the door panels and upper dash piece. Help me out with this. I am planning to start this mod within a few weeks. Lastly I have a few photos from my previous vehicle and a carbon mod I did in the engine compartment to give you an idea of what the process is and what the final look will be. That was done in the 8 harness satin (8hs). |
08-13-2012, 10:21 PM | #2 |
My initial thought is to do the door panels and upper dash area in 2X2 black twill and the leather dash piece in the 8HS with a vertical orientation of the cloth.
I gather my energy by feeding on the life-force of children.
08-13-2012, 10:22 PM | #3 |
Drives: 2010 Camaro LS V6 Join Date: Jul 2010
should look killer. good luck!
C-LO or Sonic
"Without Struggle there is no progress" I am your best nightmare! |
08-13-2012, 10:23 PM | #4 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
i thought about doing this myself but instead i got a zl1 suede insert
Email: rdurso1@yahoo.com |
08-13-2012, 10:26 PM | #5 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
thats real nice.where did you get the CF kit ?
08-13-2012, 10:31 PM | #6 |
I ordered the carbon fiber cloth and resin from C & J Composites Technology. http://www.cjcompositestechnology.com I also bought some cloth from Composite Envisions http://www.compositeenvisions.com
The material is very inexpensive, but the labor to get everything looking great is why everything made of carbon fiber is so expensive.
08-13-2012, 10:39 PM | #7 |
Here's a couple of pictures of red and blue carbon fiber as it would look on a finished trim piece.
08-13-2012, 10:42 PM | #8 |
very true, the outcome is well worth it tho. thank you very much for the link
08-13-2012, 10:46 PM | #9 |
Composite envisions has a green carbon fiber that you could use.
08-13-2012, 10:47 PM | #10 |
I'm not sure if the color would match well or not though.
08-13-2012, 10:50 PM | #11 |
The resin I use is UV stabilized and the tint on my car blocks 99% of all UV rays. So I'm not too worried about that.
08-14-2012, 12:27 AM | #12 |
I checked out your site and your stuff looks really good!
08-14-2012, 02:04 AM | #13 |
Im really liking the red carbon
08-14-2012, 02:08 AM | #14 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
Good luck with your project. I've done some overlay, but its not easy and takes a lot of patience. I'm sure your pieces will look great.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
Thread Tools | |
