Old 08-14-2012, 09:04 AM   #1
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
1LE Sway Bars
Does anyone know the part numbers for the front and rear sway bars? The 27 and 28 mm bars look like a great upgrade for my 2012.
Cuda7050 is offline   Reply With Quote
Old 08-14-2012, 11:34 AM   #2
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Check here
http://www.camaro5.com/forums/showthread.php?t=237956
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 08-14-2012, 12:26 PM   #3
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
Thanks Roger, I have been following that thread but it only lists the part numbers for the ZL1 sway bars which I believe are 25 mm in front and 28 mm in back. The rear bar part number is probably the same given the rear bar on the 1LE is 28mm, but the 1LE front bar is a 27mm according to my information. Therefore the 1LE front bar part number should be different.
Old 08-14-2012, 12:42 PM   #4
RogerBzSS
RogerBzSS's Avatar
Agreed!!
Old 08-14-2012, 09:30 PM   #5
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
Okay, I was able to get the following part numbers and prices from my local chevrolet dealer:
Front Sway bar PN #22812946 $125.72
End Link PN #22842515 $35.36
End Link PN #22842516 $35.36
Bush Ins. PN 22761218 $7.40 (2)
Lt Clamp PN #22757041 $8.39
Rt Clamp PN #22831253 $6.23
Rear Sway Bar PN #227862 $129.12
Although he was real nice and offerred a 20% which resulted in the above prices, I am not super confident he got me the correct part numbers for the 1LE sway bars and related components. Maybe someone esle can confirm these part numbers.
I checked these numbers on GM Parts Direct and they appear correct, plus they are another 20% less.
Old 08-15-2012, 10:38 AM   #6
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
I can confirm everything but the front sway bar, because they are also ZL1 parts. Those of us that have been upgrading to ZL1 bars have found that the bars come with bushings and clamps. No need to buy separate. If its in his system they should be the correct part numbers.
Front Sway End Link (passenger side) - 22842515 - $25.95
Front Sway End Link (drivers side) - 22842516 - $25.95
Rear Sway Bar - 22786260 - $94.76
Rear Sway Bar Endlink (2) - 22761221 - $13.70
Rear Lower Control Arm (2) - 20942237 - $31.14 > Only needed for 2010-2011 cars.
Rear Toe Link (2) - 22845487 - $56.54
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 08-17-2012, 11:41 AM   #7
nak3dsnake
nak3dsnake's Avatar
Here's the whole package guys:
http://www.camaro5.com/forums/showthread.php?t=244570
