Solo Performance
Old 08-14-2012, 07:38 PM   #15
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
do you have the 2013 schematic inside rearview mirror to compare? I really interested in this retrofit
DWALEX is offline   Reply With Quote
Old 08-22-2012, 11:09 PM   #16
DWALEX
DWALEX's Avatar
I think this mirror uses the Low Speed GMLAN serial data for auto-dimming. allowing it to compensate for the amount of light inside the vehicle like the display radio or Driver Information Center Display
Old 08-23-2012, 03:20 PM   #17
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
If it did this I would assume it would need to have a light sensor somewhere near the mirror but not in the mirror. My current mirror only dims itself at night when there is light glaring right into it so I'm assuming the 2013 mirror will work the same way.
I ordered one so I report back on what happens when I plug it in. I'm expecting the OnStar stuff wont work but I'm hoping the dimming bit still works.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 08-23-2012, 04:18 PM   #18
DWALEX
DWALEX's Avatar
I'm waiting for mine also. The old mirrors do not have the auto-dim function in the buttons, the new ones have it. The light is intense in the day , and tenuous in the night.
my theory is that use the Ambient Light Sensor
Old 08-24-2012, 03:39 AM   #19
ven
ven's Avatar
Drives: 2012 1ls camaro all black (so far)
Id love to do this to my 12 as well. Did anyone get a part number yet?
ven is offline   Reply With Quote
Old 08-24-2012, 07:51 AM   #20
The Stig
knows 2 facts about ducks
The Stig's Avatar
Try sending Maureen@RodgersChevrolet a private message?
Click to view my build thread
Old 08-24-2012, 10:01 AM   #21
DWALEX
DWALEX's Avatar
patrick@gmpartshouse.com
Old 08-29-2012, 08:20 PM   #22
brandon.rush1
Drives: 2012 Black Camaro 2SS
anyone got any new news on this?!
brandon.rush1 is offline   Reply With Quote
Old 08-29-2012, 08:21 PM   #23
Soonerfan
Soonerfan's Avatar
Drives: 2013 Ash Grey Camaro
That mirror is sweet....I love mine!!
Soonerfan is offline   Reply With Quote
Old 08-29-2012, 08:34 PM   #24
DWALEX
DWALEX's Avatar
I'm waiting for my mirror to start working on this retrofit
Old 09-04-2012, 01:22 PM   #25
Agent WD-40
I should have mine at some point this week. I'll report my findings.
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 09-06-2012, 11:59 AM   #26
brandon.rush1
Keep us informed!! Do you know the part number by chance?
Old 09-06-2012, 12:28 PM   #27
Agent WD-40
Well I got the mirror yesterday and was able to install it. The short version is it doesn't work when you plug it in on my 2010. The longer version is below.
The Good:
1) It looks much better than the large plastic frame stock mirror
2) It blocks a lot less of the windshield than the stock mirror
3) The mount and wire harness plug are identical to the old mirror so it fits well
4) It has all of the same functions as old mirror (the eye for the dimmer and indicator lights are behind the mirror glass which gives it a much sleeker appearance)
The Bad:
1) The windshield on the 2010 has a blacked out area behind the mirror and some sort of box or antenna mounted behind it. With the smaller 2013 mirror this is more visible than before. The 2013 windshield has a cleaner appearance behind the mirror.
2) It doesn't work. I plugged it in, turned the car on, and then nothing. The buttons on the mirror don't respond and the mirror will not dim if you shine a light on it (to simulate a cars headlights from behind).
I would have probably been OK if the mirror would have at least dimmed; I don't really use the other functions on the mirror so I wouldn't miss them. I would guess if you can figure out which wires are power and ground you can re-wire it so it will at least dim.
Does anybody know which pins on the 2013 mirror plug are power and ground? If somebody can tell me I'll try to test the dimming functionality.
I'm not sure what the part number is. There may be one on the box it came in, but I'm not sure.
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 09-06-2012, 12:31 PM   #28
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
that should plug and play in a 2012, but it doesn't have the LCD, so won't work for me..
Mr. iNCREDIBLE is offline   Reply With Quote
