Solo Performance
Old 09-06-2012, 02:26 PM   #29
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
in 2010, the dimming use Ignition Voltage(PK) and Back up Lamp Supply Voltage BCM(L-GN) and power buttons comes from Communication Interface Control Module(Keypad Signal(D-GN/WH), Keypad supplay voltage(L-GN/BK), Keypad greend LED signal(YE/BK) and keypad red LED signal(BN/WH), and Ground (BK).
probably use the same wire colors.
tomorrow I will get mine and I will see what I can do
DWALEX is offline   Reply With Quote
Old 09-06-2012, 02:36 PM   #30
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Originally Posted by Mr. iNCREDIBLE View Post
that should plug and play in a 2012, but it doesn't have the LCD, so won't work for me..
I was thinking the same thing. I'd be very interested if it had the LCD.
Bye bye, Bumblebee!
Old 09-06-2012, 02:45 PM   #31
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Originally Posted by Agent WD-40 View Post
Well I got the mirror yesterday and was able to install it. The short version is it doesn't work when you plug it in on my 2010. The longer version is below.
The Good:
1) It looks much better than the large plastic frame stock mirror
2) It blocks a lot less of the windshield than the stock mirror
3) The mount and wire harness plug are identical to the old mirror so it fits well
4) It has all of the same functions as old mirror (the eye for the dimmer and indicator lights are behind the mirror glass which gives it a much sleeker appearance)
The Bad:
1) The windshield on the 2010 has a blacked out area behind the mirror and some sort of box or antenna mounted behind it. With the smaller 2013 mirror this is more visible than before. The 2013 windshield has a cleaner appearance behind the mirror.
2) It doesn't work. I plugged it in, turned the car on, and then nothing. The buttons on the mirror don't respond and the mirror will not dim if you shine a light on it (to simulate a cars headlights from behind).
I would have probably been OK if the mirror would have at least dimmed; I don't really use the other functions on the mirror so I wouldn't miss them. I would guess if you can figure out which wires are power and ground you can re-wire it so it will at least dim.
Does anybody know which pins on the 2013 mirror plug are power and ground? If somebody can tell me I'll try to test the dimming functionality.
I'm not sure what the part number is. There may be one on the box it came in, but I'm not sure.
It works with the BCM, if it does not get a on command from the BCM it will not come on, If you want to send it to me i can try to make a harness for it?
The 2012 has 2 set ups for the mirrors one wit the LCD and one with out, and there not wired the same you dont have a power wire in there.
Originally Posted by DWALEX View Post
in 2010, the power dimming(PK) comes from the Ignition run relay, and power buttons comes from Communication Interface Control Module(Keypad Signal(D-GN/WH), Keypad supplay voltage(L-GN/BK), Keypad greend LED signal(YE/BK) and keypad red LED signal(BN/WH), and Ground (BK).
Dont know on this mirror, but the the LCD does not get power from the Ignition run
Old 09-06-2012, 02:59 PM   #32
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
yeah I know, what I meant is the 2013 has the video in the MyLink so no LCD in the mirror so a 2013 mirror won't work for me, I want the LCD in the mirror.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 09-06-2012, 03:14 PM   #33
carguyusa
carguyusa's Avatar
Drives: '71 Buick GSX- '12 2LT/RS-Silverado
Price?
carguyusa is offline   Reply With Quote
Old 09-06-2012, 06:19 PM   #34
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
Thanks for the offer but I'll just stick with the stock mirror. I'll sell you the mirror if you want it. If not, I'll just return it.
For those that want the GM Part #: 13580912
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 09-06-2012, 07:09 PM   #35
2SSRS@Gen5diy
Hold on to it for a week or so i may have a harness made to work on 2012 mirror and if it does then this will be that same way.
Old 09-06-2012, 08:04 PM   #36
topgun966
Drives: 2012 Camaro LT1
Will this work on a 2012 without much mods? From what I am reading there is not much difference between 2012-2013 as far as the guts.
topgun966 is offline   Reply With Quote
Old 09-06-2012, 08:33 PM   #37
2SSRS@Gen5diy
Dont know right know.
Old 09-07-2012, 01:19 PM   #38
Agent WD-40
I'll do that. Let me know when you have something.
L99 - 440 RWHP
Roto-Fab Intake
Corsa Exhaust
Old 09-07-2012, 03:11 PM   #39
Bodih
I Got My Orange Crush
Bodih's Avatar
Drives: it like I stoles it...
Never dreamed I see the day we couldn't swap out a rear view mirror because of a computer interface incompatability!!!
Keep us posted!
My love is in league with the freeway. Its passion will ride, as the cities fly by, and the tail-lights dissolve in the coming of night. And the questions in thousands take flight ~Robert Plant - Big Log~
Bodih is offline   Reply With Quote
Old 09-07-2012, 03:26 PM   #40
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Keep us posted!
An still no light in the glove box.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 09-08-2012, 07:12 PM   #41
2SSRS@Gen5diy
Mirror is on the way and then we will wire it.
Old 09-08-2012, 07:31 PM   #42
DWALEX
DWALEX's Avatar
I'm working to find the power wire. The new mirror only has 7 wires.
Any kind of help is welcomed
