SDTW Custom Wheels & Tires
Old 08-14-2012, 11:22 PM   #1
vandervortadam
Drives: 2010 Camaro 2ss black 21's
91 octane no ethanal or 93 octane with up to 10% ethanal
I am about to get a jre tune in a few days. Just wondering what octane I should go with? ethanal or not? Does it help or hurt your motor? Any input would be great.
Thanks,
Adam
vandervortadam is offline   Reply With Quote
Old 08-15-2012, 05:58 AM   #2
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
what do you typically purchase?
what is the fuel octane most widely available?
forget the ethanol / non ethanol debate IMPO..
I go 93
it does not mean you cant run 91, just don't beat the snot out of it when you need to fill up on 91, and use 93 as the primary fuel at you're favorite fuel stop
but if 91 is the most highly available fuel then go with a 91 octane tune?
I would also Talk with Ted
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 08-20-2012, 07:06 PM   #3
redredrage
redredrage's Avatar
Drives: 2010 Camaro SS manual all stock
Thanks,
Adam
Running 93 or slightly above seems to feel the best.
I purposely add 5 gallons of e85 plus 11 gallons of 89.... puts me right around 93 octane....... computer adjusts and adds more fuel for the ethanol
redredrage is offline   Reply With Quote
