07-07-2013, 08:59 AM | #155 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Any time that you change the car's ride height or disassemble its suspension for any reason, you need to at least check the alignment. It may be good, close enough, or not and needs adjustment.
Just the clearances in the various holes for the bolts that go through them may allow the bolts to not go back together exactly the way they were before. Kind of separate, but when you swap in all those parts which are intended for harder cornering you'll probably want a fussier and more aggressive alignment than OE for an SS to take better advantage of it all. Norm |
07-31-2013, 08:11 AM | #156 |
I was poking around partstaxi.com and they have a package for 1LE suspension minus hubs and rear cradle bushings. The part numbers they list do not match with those I've seen on this thread. Is there something I'm missing?
http://www.partstaxi.com/products.php?partID=1651 22812942 Front Stab Bar Asm (bar, links, bushing, clamp, nut) 1 22786260 Rear Stab Bar Asm (bar, bushing, clamp, bolt) 1 22761221 Rear Stab Bar Link 2 22812982 Front Strut Asm, LH (strut, spring, mount) 1 22812983 Front Strut Asm, RH (strut, spring, mount) 1 22981391 Rear Shock 2 22922445 Rear Shock Mount, LH 1 22922446 Rear Shock Mount, RH 1 22845487 Rear Toe Link 2 |
08-04-2013, 09:57 PM | #157 | |
Drives: Camaro Join Date: Feb 2010
what alignment shall i use ?
what wheel alignment spec shall i use ? FE2 or FE6 ? I can't find FE6 spec, thank you !
08-11-2013, 01:46 PM | #158 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Anyone else confirm that going from 2013 FE4 to 1LE FE6 is just the rear shocks and shock "bumpers", f/r sway bars, wheel bearings, and cradle bushings? Everything else looks same as FE4 including springs and front struts.
08-11-2013, 02:08 PM | #159 |
Unapologetically American
Fairly sure it was mentioned that front struts were monotube.
Sent from my ADR6425LVW using Tapatalk 4
2018 ZL1
08-12-2013, 06:29 PM | #160 |
Drives: '10 Camaro LTRS, '12 Pro4x Frontier Join Date: Jul 2009
I already have upgraded endlinks and sways that fit into my 2010 FE2. If I just wanted to upgrade to the 1LE shocks and struts my endlinks wouldn't fit any more is that correct?
08-12-2013, 06:54 PM | #161 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Correct
09-24-2013, 11:34 AM | #162 |
Drives: 2018 ZL1 A10 Join Date: Mar 2013
One quick question, If i buy the 1LE sways are endlinks needed as well. These will be going on a 2013 ss.
09-24-2013, 01:53 PM | #163 |
COTW 5/06/2013
Yes
01-23-2014, 09:13 PM | #164 |
Drives: 2010 camaro ss Join Date: Oct 2011
bump ...are the rear toe link needed , i have a 2010 camaro ss and upgardind just the sway bar
01-23-2014, 09:14 PM | #165 |
Drives: Camaro Justice Join Date: Jun 2007
01-23-2014, 09:36 PM | #166 |
02-03-2014, 07:11 PM | #167 |
I'm having an issued I'm installing 1le front sway bar and notice the end link are thicker , from reading here people are mentioning the bolt are 12mm for the end link ,I have a 2010 with 10mm , anyways my issue is I don't have 12mm bolt does anyone the the pn # for the bolts ?
02-03-2014, 07:31 PM | #168 |
Ok so I have to drill a larger hole where the upper end link connects to the strut bracket part since is made for a 10mm on my coilovers .
Thread Tools | |
