JDP Motorsports
Old 10-05-2012, 12:04 PM   #71
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Originally Posted by nak3dsnake View Post
My 1LE parts are here!
So what all did you order? Let's see some pics.....please!!!
blazzin1 is offline   Reply With Quote
Old 10-05-2012, 01:23 PM   #72
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Originally Posted by RacnJsn95 View Post
The rear swarbar, and toe link part numbers are the same as the ZL1 part numbers in the previous part number thread... The front sway bar number is different though.
The 1LE has a slightly larger front bar.
Old 10-06-2012, 01:41 AM   #73
dcplus14
dcplus14's Avatar
Drives: '12 Camaro 2SS/RS/Hurst
My 1LE sways are here! Hopefully will install in the morning, although kind of have the urge to do them now!
Not a fan of how they were packaged/shipped though, does that look normal?
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars]
dcplus14 is offline   Reply With Quote
Old 10-06-2012, 10:09 AM   #74
L99CAMA2011
L99CAMA2011's Avatar
Excessive is more like it. Yeah that's GM packaging. Lower cost to wrap it than box it for shipment.
Old 10-06-2012, 11:14 AM   #75
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Picks will follow, got the package sans wheel hubs.
Normal, mine were packaged exactly the same way. So were my rear LCA's.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 10-06-2012, 04:18 PM   #76
nak3dsnake
nak3dsnake's Avatar
Everything from the 1LE package sans wheel hubs. My rear shock mounts unlike Synners are lacking the cutouts for mag ride or adjustable coil overs. I can also confirm that the front end links are the 12mm variety. The yellow front strut insulators are on all current Camaro's, i figured I'd upgrade those while I was at it. My sway bars and rear LCA's were also package poorly and are covered in scratches and dings. Gonna need some wire brushing and repainting on some of these parts.
Old 10-06-2012, 08:27 PM   #77
Synner
Drives: not stock
Thats weird, yours has the better bushings though which is all that matters.
Old 10-07-2012, 10:56 AM   #78
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
How much did all that set you back? It took me a couple years to piece together all of my suspension upgrades.
1977and2010 is offline   Reply With Quote
Old 10-07-2012, 11:35 AM   #79
nak3dsnake
nak3dsnake's Avatar
About a grand all together. The most expensive part was the rear monotube dampers, they were 180 a piece. I just saved my kinkles till I saw something I liked. I'm looking at Pedders Street I inserts and maybe the alignment kit to go with these. I haven't decided what to do with springs yet, but the 1LE uses the same springs rates as the SS.
Old 10-07-2012, 02:07 PM   #80
blazzin1
blazzin1's Avatar
Aren't the front shocks/struts on the 1LE the same as what's on the SS?? Just curious?
Old 10-07-2012, 02:23 PM   #81
JusticePete
The 1LE gets monotubes.
Old 10-07-2012, 02:49 PM   #82
blazzin1
blazzin1's Avatar
I thought that was just in the rear though, hmmm....I guess maybe I'm wrong?!?!?
Old 10-07-2012, 04:33 PM   #83
nak3dsnake
nak3dsnake's Avatar
No, they are not the same. But im not about to crack one open to see if its monotube or not.
Old 10-07-2012, 05:06 PM   #84
JusticePete
Monotubes all round.
