Old 08-17-2012, 05:13 PM   #1
Pollock
LT1 M6
Pollock's Avatar
Drives: 2018 1SS/1LE
Drag racing a manual
Is it possible to be consistent with a stick. Any tips to do so. I can't even get a decent light. I have plenty of racing experience but I had an auto with a transbrake.
Pollock is offline   Reply With Quote
Old 08-17-2012, 06:46 PM   #2
Neumatic
Neumatic's Avatar
Drives: 2010 Camaro 2SS M6
I don't know enough to give advise but I know for a fact it is possible to run consistent with a stick. There was a guy at C5F, who is a member on here that had all his runs within .05 seconds of each other with his stick. Takes a lot of practice but it is possible.
Neumatic is offline   Reply With Quote
Old 08-17-2012, 06:52 PM   #3
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Old 08-17-2012, 07:10 PM   #4
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
I'm still learning, but, I became more consistent when I installed a dual mode shift light. It has launch rpm then goes to shift rpm once headed down the track.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 08-17-2012, 07:15 PM   #5
96MrBass
96MrBass's Avatar
Drives: GM
Tornado what shift light did you install?
96MrBass is offline   Reply With Quote
Old 08-17-2012, 07:50 PM   #6
TornadoSS
WICKDSS
TornadoSS's Avatar
Raptor dual mode shift light. Got it from Apex Speed.
Old 08-17-2012, 08:06 PM   #7
mlee
www.CamaroFans.com
mlee's Avatar
Nice... I've been using the shift lights in the ZL1 HUD unsuccessfully...
Old 08-17-2012, 08:13 PM   #8
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
there is a reason 999 of 1000 drag cars are auto.
horses for courses......
Higgs Boson is offline   Reply With Quote
Old 08-17-2012, 08:57 PM   #9
TornadoSS
WICKDSS
TornadoSS's Avatar
I just enjoy being pissed at myself trying to get down the track consistently with a manual tranny! Lol! Makes me push myself harder to keep getting better.
Old 08-17-2012, 11:27 PM   #10
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
You will never be as cosistent with a manual as you were with an auto with a transbrake.But,Practice will help to some extent.If someone is running a manual
and all their runs are within .o5 of each other...They have electronics to help and they are very lucky.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 08-18-2012, 07:32 AM   #11
Pollock
LT1 M6
Pollock's Avatar
Would a two step box help dramatically? I am thinking it would.
Old 08-18-2012, 01:23 PM   #12
outlawprostreet
outlawprostreet's Avatar
Drives: 2012 Turbo SS
The problem with the 2 step is you have to dump the clutch or it will rpm flash if you slip it out. When I bracket raced my stick mustang I would stage at like 2500 rpm and just slip the clutch almost like leaving a traffic light. I was pretty consistent in the 14.60's and .70's. For the light try staging deeper till you can get it where you can leave as the bottom bulb turns on and cut a light.
LS3 M6 w/ Turbonetics stage 1 turbo kit
Huron Speed twin 64's waiting to be installed
outlawprostreet is offline   Reply With Quote
Old 08-19-2012, 11:12 AM   #13
Pollock
LT1 M6
Pollock's Avatar
So when do you floor the pedal. After the clutch is fully released.
Old 08-19-2012, 11:55 AM   #14
outlawprostreet
Yes. Let all the slack out of the peddle where its right on the verge of creeping. Then slide the clutch out like you're leaving a traffic light and work into the gas at the same time. Once the clutch is all the way out mash the gas. Also instead of doing a burnout (i was always on street tires) I went around the water box and would do a practice launch (dry hop) to the line.
The problem with dumping the clutch (without a centrifugal lock up clutch) is you're always going to either spin or bog. Slipping the peddle IMHO is the closest way to leaving like an auto does
