JUICEDMOTORSPORTS
Old 08-17-2012, 08:26 PM   #1
CamaroV6
Drives: Camaro V6 1LT Manual
Trifecta tune question
hey guy's ive had my tune for a while now and I wanna put the ghost cam on it..Vince told me that i could do it with the new version of EZflash by myself but when i choose the ghost cam and then i hit the button below it nothing happens what do i have to do after im stuck??? can anyone give me some insight in to this thanks guy's.
CamaroV6 is offline   Reply With Quote
Old 08-17-2012, 08:35 PM   #2
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
ok noobie here you go!
in easy flash ull see one of the tabs at the top that says "Program" bring it down
then go to "adjust tune setting"
then click on the "LLT"
then "set ghost cam" and choose how aggressive you want it
And dont worry about not knowing, at least ur using the right ezflash because I wasnt when I first tried it lol
nikos30 is offline   Reply With Quote
Old 08-17-2012, 08:44 PM   #3
CamaroV6
l
ok after this what do i do??? i got uo to that part.
Old 08-17-2012, 08:53 PM   #4
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
After you set it how you like it, you need to run the tune again so the car get the new settings...
Monchy36 is offline   Reply With Quote
Old 08-17-2012, 09:00 PM   #5
CamaroV6
got it cool thank you.
Old 08-17-2012, 09:01 PM   #6
nikos30
HT5 EastSide
nikos30's Avatar
then you just install the tune. It will reset if you close out of the program. also, the car needs to reset a certain temperature in order for it to turn on, so you got to wait for it.
Old 08-17-2012, 09:35 PM   #7
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Temp has to be 170* and the cruise control set to off.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
