Old 08-18-2012, 04:03 PM   #15
Phat Ralph
Phat Ralph's Avatar
Drives: 2011 Camaro 2SS/RS 6spd Synergy
If you setup like the other guys how are you going to beat them
Well, I do not have anything to hide from the Camaro5 guys! Only see GT-R's, Vette's and Stang's at the track.......Camaro guys need to get to the track in the Mid-Atlantic region.
I will try those preload setting next week at Carolina Motorsports Park!
2011 Camaro RS/SS Synergy - (Pedders Xa's Coilovers, ZL1 Sways, SS Brake Lines & Bushings), Hotchkis Chassis Brace & Strut Bar, DSS 1000hp Road Race Axles, Nitto NT-01's, TSW Wheels, ADM CAI, Borla ATAK, HAWK, Granatelli Rotors, Barton Shifter, Tick Performance Clutch Line, MRS Exhaust Tips, Elite Catch Can.
Phat Ralph is offline   Reply With Quote
Old 08-18-2012, 04:20 PM   #16
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Does your 5th Gen feel a bit unsettled when you use the gator backs in the corners?
Old 08-18-2012, 06:06 PM   #17
Parabolica
Drives: 2011 2SS
Great stuff Ralph. Subscribed to see where this goes..
Parabolica is offline   Reply With Quote
Old 08-18-2012, 06:17 PM   #18
JusticePete
VIR Specialist
About 1.38 Gs.
Old 08-18-2012, 06:52 PM   #19
Parabolica
Drives: 2011 2SS
Old 08-19-2012, 08:21 AM   #20
Phat Ralph
Phat Ralph's Avatar
Car is pretty stable even over the FIA gators at VIR! Here are a couple video's of VIR last month. I can say one thing is that I knocked the toe out of the front of the old girl. Best time is a 2:18, that is pretty respectable....
Off course at 15:20......
Old 08-19-2012, 08:41 AM   #21
Phat Ralph
Phat Ralph's Avatar
Hmmm last Xa instructions I received said 3 mm preload up front and 10mm in the rear. I do play with it and have mine at 5 all around.
Last advice I got from Pete (driving my car) was to put the front sway to full soft and full hard on the rear bar.
Thanks! I have older instructions.....but we netted out at the same settings.
Old 08-19-2012, 01:18 PM   #22
JusticePete
VIR Specialist
You are running on 19s, correct?
Old 08-19-2012, 01:21 PM   #23
Phat Ralph
Phat Ralph's Avatar
18"'s.....PMed you all my setup info!
Old 08-19-2012, 01:47 PM   #24
Parabolica
Drives: 2011 2SS
What happened to keeping it in the thread???
Old 08-19-2012, 02:16 PM   #25
JusticePete
VIR Specialist
I have over 30 PMs to get through tonight
Old 08-22-2012, 01:33 AM   #26
Parabolica
Drives: 2011 2SS
Old 08-22-2012, 02:52 PM   #27
Phat Ralph
Phat Ralph's Avatar
Originally Posted by Parabolica View Post
Persistent!
Here you go.......
  • Wheel and tire package details: Nitto NT-01 275/40R18 100AA, on TSW 18x9.5 wheels
  • Detailed list of powertrain modifications: Borla Atak Cat-back & CAI w/race scoop, DSS 1000hp Road Race axles
  • Detailed list of all suspension modifications: Pedder’s XA’s set 23F & 25R, 5mm preload on all springs. Front – Radius Rod Bushing Inserts, Steering Rack bushing, Caster Eccentrics. Rear – LCA Bushings. Hotchkis Chassis Brace and Strut Bar.
  • Current Alignment specifications:
Front: Caster Maxed out at 7.3
Camber is -1.9
Toe is total -.250
Rear: Camber was at -2.0 now just changed to -1.1
Toe is total +.125
  • Corner weights
Front = 1851 Left=973 Right=878
Rear = 1859 Left=938 Right=921
Total = 3710
  • Ride Heights Pedder’s Style: 648mm Front & 653 Rear, measured using 20" wheels.
  • Sway bar sizes and setting if adjustable: Pedder’s 27mm front on short/stiff setting with adjustable endlinks and Pedder’s ZL1 32mm rear bar with 10mm of thread showing on top.
  • RWHP: Stock at about 370rwhp
  • Brake Package including fluid and pad details: Stock with Pedder’s SS lines, HAWK DTC-60 Front, DTC-30 Rear, Motul 600 Fluid, Stock cheap rotors.
Old 08-22-2012, 02:55 PM   #28
JusticePete
VIR Specialist
I'll get a detailed reply up later today.
