BORLA
Old 05-28-2009, 09:34 AM   #43
SicSix6
The Demon Photographer
SicSix6's Avatar
Drives: 2010 1SS IOM Camaro
Originally Posted by voyager77 View Post
any comment on how hard they are to install? DIY?
It takes me 7 hours to install long tubes on a 93-2002 F-body. It looks like the clearances on these cars is better. So it should be easier.
1SS IOM LS3, GM 4-pack guages, SLP SS Front Emblem, Roto-Fab CAI, Solo Performance Mach X Exhaust, Barton Industries Short Throw Shifter
SicSix6 is offline   Reply With Quote
Old 05-28-2009, 09:40 AM   #44
SicSix6
SicSix6's Avatar
Please PM me prices for emissions legal system with Cat's and all O2 provisions. Thank you.
Old 05-28-2009, 09:47 AM   #45
JDBeck23
Drives: 2010 Camaro, 2SS/RS
Looks like unbolt and rebolt. From what some have said, there's a ton of room engine bay on the new camaro's. Which is a blessing for long tube header installs. If you have floor jacks and a wratchet set, you should be good to go.
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 05-28-2009, 09:51 AM   #46
JDBeck23
Originally Posted by H3LLJumper View Post
Legal in Virginia? :[
Im sure we'll be fine. If some jerk at the inspection station is so concerned about your exhaust that he's gonna look under the car, you have a bulge just passed the headers... that means you have cats.. and you're fine.
It's not like they have pictures of the stock exhaust system to compare yours to. You can tell them that they are the factory cats cut from the old exhaust and welded into the new one. They cant prove it otherwise.
Now if your county has the sniffer, I hope you pass the sniffer. But if it makes you feel any better, I had a 2001 Cobra with Bassani catted x pipe and bassani catback and it passed CA emissions with flying colors. We should be fine on the camaro in Va.
2010 2SS/RS CGM
Old 05-28-2009, 10:21 AM   #47
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Originally Posted by markssylver View Post
i talked to someone at arh the other day and they said with their headers and x pipe setup there was really no need for aftermarket mufflers as the stock ones were pretty much free flowing and the only reason to go after market would be to make your car LOUD
Or for removing like 40lbs of useless weight and the terrible underhang.
Kyle2k is offline   Reply With Quote
Old 05-28-2009, 11:08 AM   #48
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
AWESOME GAINS! To the OP's post earlier - where the pipes neck down to about 2.5'-inches is the merge collectors ARH use. QTP is the only other major company I know of that use these collectors standard. These promote scavanging of the exhaust by keeping the velocity of the gases as high as possible. Kooks has something similar on many of their LTs, but they're not quite as good, from the looks of them (they have true high velocity merge collectors for an additional cost though for some models, last I checked). Anyhoo, these are great gains! I didn't really think they'd be this high, but considering the numbers - WOW! Has ARH mentioned if they are going to offer additional sizes and stepped primaries for the 5th Gen too?
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 05-28-2009, 12:29 PM   #49
SSINSTR
Michelin Man Assassin
SSINSTR's Avatar
Drives: '10 IBM 2SS/RS LS3
So is it OK to run long tubes w/o a tune? I know it would benefit from a tune but it was my understanding that to compensate for the better breathing a tune was necessary with LT's. Oh and great looking headers, a set just might be in my future
SSINSTR is offline   Reply With Quote
Old 05-28-2009, 01:00 PM   #50
bballr4567
Drives: 2016 Camaro 1LT M6
If you spend 1k plus on LTs you might as well put down the 300-400 to get a tune and the extra 20 HP.
bballr4567 is offline   Reply With Quote
Old 05-28-2009, 01:31 PM   #51
bad2000z
bad2000z's Avatar
Drives: 2005 C6
What were the before and after dyno #'s? Maybe I missed it..
2005 Victory Red C6
bad2000z is offline   Reply With Quote
Old 05-28-2009, 02:37 PM   #52
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
My only question is, do they install without having to lift hte engine. They slide right in?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 05-28-2009, 02:39 PM   #53
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I don't recall reading about moving the engine around for the G8 LTs from ARH, so I imagine it would be pretty similar in our case. It seems like ARH, among many other good things, is known for a pretty "easy" bolt-on affair, as far as LT installs go.
Old 05-28-2009, 02:45 PM   #54
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Sometimes the 02 sensors don't light-off quick enough and set of the MIL. A lot of times, I've seen the tuner (mine included) turn off the 02s so there isn't a problem. You could run 02 simulators but could still have problems I imagine if the front aren't heating up enough. I've had that problem too.
The newer PCMs compansate better than the older ones though, don't they? I'm not going against what you're saying though, because I've always planned for a tune into my LT budget. I'll tell you that I gained almost 30 more RWHP going from mid-lengths (which weren't known to be pretty good, though not as good as LTs) and a crappy canned tune to LTs and a good dyno' tune. Yeah - it costed another $400, but it was worth it to run good and not smell like I was trying to kill all the mosquitos in my area.
IMVHO - save and plan for a tune too
Old 05-28-2009, 02:46 PM   #55
CWI
CWI's Avatar
Thanks radz, seems these are comparable gains to what Tag got with his Stainless Works.
Old 05-28-2009, 02:49 PM   #56
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
I would love to gain 50HP and have the more open feel of high-flow cats and headers of this quality, but I cannot see giving GM or my dealer a way out of warrantee claims on a new model car. Plus Emissions under the current administration will probably become federally mandated to match California......not worth laying out all that cash for all that uncertainty.
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Pedders partnering with GM Racing on Camaro suspension Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 6 09-30-2008 01:14 PM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 04:33 PM
