Gen5DIY
Old 08-20-2012, 11:47 AM   #1
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
3.70 gears and 1/4 mile runs
Could the gears be hurting my 1/4 mile time? I noticed that the car shifts (into 4th, I guess) right near the end of the 1/4. I never went to the track when it was stock, so I don't know how it shifted then, but I'm thinking I would've finished in 3rd. What effect does this have on time, trap speed, etc?
E.T. is offline   Reply With Quote
Old 08-20-2012, 12:10 PM   #2
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
My guess is your hitting 5th gear not 4th. I have 3.70's and will be switching them out this winter to 3.42's.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 08-20-2012, 12:13 PM   #3
MudderFinger
Drives: 2011 IOM SS/RS
I have 3.45 and I cross the finish line in 4th@ 6450rpms
MudderFinger is offline   Reply With Quote
Old 08-20-2012, 12:56 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I'm bolt-on and it shifts into 4th right before the traps, i'm thinking it's your 5th gear shift.
3.70's with a 28.7" tire is still only like a 3.23 with 26's. Plus our cars are heavy.
If I don't try a blower maybe I'll try some 3.91 gears.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-20-2012, 01:28 PM   #5
blackflag
blackflag's Avatar
Drives: 2012 2SS 45th
Mine hits 4th right before the traps as well. Usually shifts around 101-102.
#1 2012 NMCA/LSX Challenge Series
2012 2SS 45th A6
Thanks to our Sponsors:
coldairinductions.com (Cold Air Inductions)
loughengines.com (Mike Lough Race Engines)
granatellimotorsports.com (Granatelli Motorsports)
blackflag is offline   Reply With Quote
Old 08-20-2012, 02:32 PM   #6
E.T.
E.T.'s Avatar
It could be fifth. Honestly, I always forget to count since I'm concentrating on driving. Would that be normal though? I thought fourth was good for speeds well into the 100s, even with 3.70s?
Old 08-20-2012, 03:00 PM   #7
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
This helped me a ton:
http://f-body.org/gears/
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 08-20-2012, 03:21 PM   #8
Pro Stock John
Writer
ET, is that 12.9@109 your best drag pass to date?
PROJECT HEAVY CHEVY
Old 08-20-2012, 03:29 PM   #9
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Mine is the same way but with stock gears. It shifts into the next gear like 3-4 car lengths before the finish. (same with paddles too otherwise I redline)
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 08-20-2012, 03:30 PM   #10
E.T.
E.T.'s Avatar
Yep, 12.87 or something....
I think another big factor is 60ft times. I'm barely under 2 sec, so I think there's room for improvement there, even on the Pzeros. Also, I've only been to the track twice, so practice makes perfect.
Old 08-22-2012, 08:10 AM   #11
scottywheels
Drives: 2010 A6 SS/RS
I have 3:70 and im over 130mph and still in fourth....
Scott(Retired Navy)(Paralyzed Triathlete)
New Car 99 Camaro SS with Dart 427, F1x, Rossler 210, 9 inch and BS3... scary ride
SOLD
2010 A6 ss/rs White-VORTECH YSI/LPE fuel system/ID 850's/LG Motorsports full Exhaust/Protorque 3400 stall/Livernois Stage 3 Heads/Cam/Bogarts/ Moroso subframes/JRE Rear with 3:70 gears/Aluminium DS/line lock/drag alignment/Suspension/JW Racing 10 pt cage/13.6 psi 719.34 rwhp 558.4 TQ/ Best Pass 1.51 60ft 10.08 136.78 mph JRE Built
scottywheels is offline   Reply With Quote
Old 08-22-2012, 01:49 PM   #12
SGT Stretch
SGT Stretch's Avatar
Drives: 2016 Hyper Metallic Blue SS
There is a lot to consider though with your build and everyone else's and that's your FI power over their bolt on power. There's a pretty long couple threads in the drive line section that lays out gears for you. Like me for example I'm swapping my stock 3.45's for 3.91's with the boltons that I have the stock gears either have tapping off the limiter in 3rd at the line or about to.. now when I go to a FI build I will go back to my stock 3.45
SGT Stretch is offline   Reply With Quote
Old 08-22-2012, 02:56 PM   #13
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
you want to cross the finish line at 6500 in fourth.
do you have an auto or stick?
manual trans with 3.91 will go 138 MPH at the top of 4th (6500)....
auto trans with 3.70 will go 132 MPH at the top of 4th (6500)....
of course, that is IF you have the power to push those MPH in the quarter. if you are going 109 in the quarter mile, then you are shifting to fourth right at 99 MPH...and crossing the finish line at 5400 RPMs.
Do us all a favor and look at your RPMs when you cross the finish line next time and you can know for sure. If this is the case, you can use even more gear. A 4.10 will cross at 119 in fourth.
btw, an auto with 3.27s will cross in third at 112 mph....probably result in a faster time.
with that said, if you want the most out of the 1/4 with stock type power and have an auto, get 4.10s. if you want up to 500 rwhp, get 3.70s. stock or bolt on power levels aren't going to push 3.70s, they will be more fun on the street though.
don't fear the gear! my race car has 5.83s....contemplating a move to 6.0s....
Higgs Boson is offline   Reply With Quote
Old 08-22-2012, 03:08 PM   #14
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
What's killing you 1/4 mile time is that 60ft.
JLE58 is offline   Reply With Quote
