Caryle Racing
Old 08-23-2012, 07:28 PM   #1
ADM PERFORMANCE
Drives: 2016 CAMARO SS
ADM ZL-650 with twist
Had another showroom new ZL1 trek from the very far
North part of the world looking for ADM ZL-650
But a little different.
I'll start posting the progress to what might be an
In between package for those that don't want to go all
The way to a 750.
ADM PERFORMANCE is offline   Reply With Quote
Old 08-23-2012, 08:53 PM   #2
RedZL1
Drives: Victory Red ZL1
Great! I'm looking forward to learning more about this "in between" configuration.
RedZL1 is offline   Reply With Quote
Old 08-23-2012, 10:31 PM   #3
MrDew
MrDew's Avatar
Drives: 2012 ZL1 #165
So is this a one upper to the 650+?
MrDew is offline   Reply With Quote
Old 08-24-2012, 03:44 PM   #4
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
Subscribed.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 08-24-2012, 05:08 PM   #5
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
If only there was a number about half way between 650 and 750 that you could call it.
Sorry, couldn't resist.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 08-24-2012, 09:05 PM   #6
ADM PERFORMANCE
Parts List:
So here is what you get:
ZL-650-
•ADM ZL1 Cold Air Intake
•ADM 10 bolt Supercharger Pulley Hub
•ADM 2.55 8 Rib 10 Bolt Pulley
•ADM Supercharger Isolator Coupling
•8 Rib Poly V Belt For 10% Overdrive
•63 lb Siemens Deka Fuel Injectors
•Injector Adapters
• ADM 93/91 Octane Dyno and Street Tune
• ADM Before and After Dyno Sheet
ZL-700- Includes all of the above and
•ADM Off Road Mandrel Bent Down Pipes
•ADM 3" 8 Rib 10 Bolt Pulley (Stock diameter)
•Magnaflow Super X 2.5" Dual/Dual Muffler(Allows stock sound with no popping)
•ADM Intercooler Resivoir and Hose Kit
•ADM 9.15" 8 Rib Dampner Ring (Allows for 11-12 psi)
•LPE Dampner by ATI
•50MM Idler
•Gates 8 Rib SC Belt
•Kenne Bell 40A Boosta Pump
•ADM Cam Install Kit
•ADM Stage 2 Cam
•PAC .600 Lift Beehive Valvesprings
Options for both of the above packages:
• ADM High Capacity Heat Exchanger
• Stage 3 Cam
• Dual Valvesprings
• 2.38" 8 Rib Supercharger Pulley
• 8.75" 8 Rib Dampner Ring
• 9.55" 8 Rib Dampner Ring
• Injector Dynamic ID-850 Injectors
• 105 Octane Offroad Race Calibration
• EFILive Autocal - Multi-Calibration Controller
• Denso IT27 or IT24 Iridium Spark Plugs
• ADM 100MM Idler
• ADM Offset Pulley Mount for 9.55" Ring or Larger
Feel free to call me for more info on this new addition ZL Performance Package.
Please note many of the packages are not emmissions legal and are for off road use only.
Old 08-24-2012, 10:21 PM   #7
ADM PERFORMANCE
Pics of the build
Here are a couple pics from this build:
Old 08-25-2012, 01:37 AM   #8
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
The things to make good safe power and then some!!!!! I like it
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 08-25-2012, 10:26 AM   #9
ADM PERFORMANCE
Oh yeah!
Old 08-25-2012, 10:51 AM   #10
Smart Line
Smart Line's Avatar
Drives: 2011 Blue1SSRS 623RWHP, 02 vette
Pm sent
2002 Vette (stock)
Team LS-3
Smart Line is offline   Reply With Quote
Old 08-25-2012, 10:59 AM   #11
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
Nice
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 08-30-2012, 10:01 PM   #12
ADM PERFORMANCE
Better late than never
We finished this car last week but I have been so busy I just could not get to the final on this car.
Here ya go:
Old 08-30-2012, 10:04 PM   #13
ADM PERFORMANCE
Dyno Video
Here is the customers video taken at ADM PERFORMANCE.
Old 08-30-2012, 11:38 PM   #14
TUCSONZL1
Drives: 2012 ZL1-#132
very nice.
TUCSONZL1 is offline   Reply With Quote
