Old 08-23-2012, 08:44 PM   #1
LS3 SSRS
Evl Bee
LS3 SSRS's Avatar
Drives: 2010 Camaro SS/RS Cyber Gray
Sequential Taillight issues
I bought the off brand sequential taillights off of ebay and they look great but after 5 sec of using the turn signal they start to flash twice as fast and pop the rear turn signal errors for both sides. I have read all the threads thus far but they are for the after burner & Techno lights and I have checked every fuse. Anyone have any ideas??????
LS3 SSRS is offline   Reply With Quote
Old 08-23-2012, 09:00 PM   #2
Calikenn
Calikenn's Avatar
Drives: 2012 Corvette GS
Maybe they need resistors?
Calikenn is offline   Reply With Quote
Old 08-23-2012, 09:13 PM   #3
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
I think some people that have had that issue just replace the bulbs with a long life bulb and that remedies the issue.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 08-23-2012, 09:30 PM   #4
LS3 SSRS
Evl Bee
LS3 SSRS's Avatar
They are the LED lights so I can't replace the bulbs and I thought about the resistors but I have not a clue where to start. I will check into that as an option.
Old 08-23-2012, 11:25 PM   #5
Parag
Drives: 2010 camaro 2SS LS3
actually resistors do the opposite from what you need. the computer is seeing too small of current, so it thinks the bulbs are burnt out. all cars blink fast to indicate a burnt light. the led lights should have came with a adapter that plugs in between the car pigtail, and the taillight. common issue to leave them out during install.
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 08-28-2012, 05:56 AM   #6
LS3 SSRS
Evl Bee
LS3 SSRS's Avatar
I was able to fix the issue by wiring in the factory bulbs for the turn signals only and hiding the bulbs with a little padding behind the taillight mounts. I am working on getting a diode to replace the quick fix or the light bulb so I do not have to worry about the bulbs burning out.
