HeadlightArmor
Old 08-24-2012, 02:09 AM   #1
locoycabron
Drives: 2010 Camaro SS
Which spark plug for 515ish RWHP
Which spark plug would you guys use on a 2010 camaro with 515 RWHP with a a big cam? I know the stock spark plug is rated 5 for heat range so the next step would be a 6.
Should i apply 1 colder heat range for each additional 100 RWHP or 2 colder heat ranges?
Would you go 2 steps for a:
NGK BR7EF or
NGK Iridium TR7IX
Or well just 1 step ahead to a 6 heat range numbered spark plug?
NGK BR6EF or
NGK TR6IX
thanks for you comments!
locoycabron is offline   Reply With Quote
Old 08-24-2012, 08:38 AM   #2
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Factory plug.
Sent from my iPhone using Tapatalk. If is spelllled wrong deal with it.
Crime2 is offline   Reply With Quote
Old 08-24-2012, 09:02 AM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
I'd try the 1 step colder Iridiums and see how they look after a few hundred miles. Better to err on the cold side.
Iam Broke is offline   Reply With Quote
Old 08-24-2012, 09:25 AM   #4
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Originally Posted by Crime2 View Post
Factory plug
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 08-24-2012, 09:53 AM   #5
Rich@BSP
Drives: wife says to many
NGK TR6 stock number 4177 NGK. NGK plugs the higher the number the colder the heat range with some plugs the lower the number the colder the heat range.
Rich@BSP is offline   Reply With Quote
Old 08-24-2012, 10:11 AM   #6
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
tr6 and see how they run, probably will load up at idle and low rpms, go with a tr5 gapped at .035.
the br plugs are for nitrous. don't waste your money on iridium. nothing performs better than copper.
Higgs Boson is offline   Reply With Quote
Old 08-30-2012, 11:30 PM   #7
locoycabron
tr6 running like a charm now ill keep posted if they get flammed or they survive gapped at .40
