HeadlightArmor
Old 08-24-2012, 10:43 PM   #1
73camarolt
73camarolt's Avatar
Drives: 2002 Camaro SS
Give me some tips of Drag Racing m6..
So i am only 17 as most know and i have only drag raced about 5 runs in my dads 5th gen. Well i am heading out to a local track with my manager from work who has a 2013 5.0. He is running about 13.0. I would be happy with a 13.5 as a best run. I am on all season so should i do a burnout? miss the water? I understand staging just want some opinions on clutch engagement, shifting points, etc.. When i did my dads SS i did a few clutch jumps just from being nervous.
2002 Camaro SS- BTR Stage 3, 799 Heads, Bolt on's Tuned by John at Broadview Automotive.. 420hp and 400tq
73camarolt is offline   Reply With Quote
Old 08-24-2012, 11:43 PM   #2
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
I always try to avoid the water. And do a lil bit of a burn out in case you might of ran through some. As far as staging I turn the pre-stage bulb on and wait for the other guy, you dont wanna double bulb someone. Meaning turning on both lights before they turn one on. Its the the unwritten rule/courtesy lol. After my prestage light and the other guys prestage light is on I nudge the car forward little by little just turning the stage light on. I rev it up to 2k and give her hell. A4 btw lol
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 08-24-2012, 11:48 PM   #3
73camarolt
73camarolt's Avatar
Yea I know about the courtesy rule. I'm alittle nervous about messing my car up though. I mean running your dads car is one thing, running your Daily driver is another.
Old 08-25-2012, 12:27 AM   #4
insidethreat07
I just wouldnt be doing any hard launches esp if you have sticky tires and hook good. Maybe rolling into the throttle then giving it hell.
2001 Camaro V6
2016 Camaro 2SS
Old 08-25-2012, 07:27 AM   #5
dmginc
dmginc's Avatar
Drives: 14 Camaro 1LS AGM
if you are nervous leave traction control on for first couple of runs and shift around 5000. with traction control off if you shift hard at 5000 the rear might break loose in which case get off the gas and roll back into it. in my t/a i could hard shift at 5500 and never had an issue but i had some sticky z rated tires where as you have all seasons that will be more prone to spinning. dont worry about running 13.5, just worry about getting down the track in 1 piece till you get more comfortable with the car. dont pull a Zabo...
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 08-25-2012, 07:56 AM   #6
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
Originally Posted by dmginc View Post
dont pull a Zabo...
3" Magnaflow cat-back, MSD 8.5mm Super Conductor Wires, NGK Iridium plugs, KN Air Filter, Halo Headlights, Shaved Air Lid, Chrome ZR1 Rims, SS Hood Scoop/Spoiler
Lee0123567 is offline   Reply With Quote
Old 08-25-2012, 09:09 AM   #7
insidethreat07
LOL. Just make sure your comfortable first couple passes, then you can really starting rowing through the gears
2001 Camaro V6
2016 Camaro 2SS
Old 08-25-2012, 11:07 AM   #8
ndtguy
^ Me. Things I write ~>
ndtguy's Avatar
Drives: 2010 Camaro SS
Send a message via AIM to ndtguy
Go around the water and do a quick burn out to clean the tires off.
I get the clutch pedal right before it engages the clutch.
The next few steps are going to depend on a lot of things(track bite, tire grip, amount of slipping the clutch just right, etc)
- bring the rpms to the desired rpm.
- slip the clutch and apply the throttle as needed.(once the clutch is out, you should be at wot.)
You want to get off the line with no wheel spin or bog, but I would rather have a hint of wheel spin. It's going to take practice.
I normally start at 2500 rpms and work my way up.
Practice makes perfect. Let us know how you do. Oh and shift at 6k rpms.
ndtguy
New DD: 2010 Camaro SS L99/A6 - bone stock.
Gone but not forgotten...
- 2001 Camaro SS m6 - SLP lid, free ram-air mod, poly sway bar bushings/end links, BMR springs and bilsteins.
- 1998 Trans Am m6, forged 347, T70;alky-water injection; intercooled, 208/230 .549/.579 121LSA, Moser 12 bolt, 561rwhp/611rwtq.
ndtguy is offline   Reply With Quote
Old 08-25-2012, 12:23 PM   #9
dmginc
dmginc's Avatar
for your first few runs just worry about getting off the line without stalling, that would be way more embarrassing then running 14+. eventually you want to do like ndtguy said but dont rush things. shifting a 6k with out traction control on can leave you spinning the rears and then you end up in a wall. get some experience and build up to that. better to be safe with a high et then to go into a wall real fast...
you do want to try to do a quick burnout to get any crap off your tires and you might want to invest in a second set of rear wheels with some sticky tires on them as all seasons are not going to do well off the line.
Old 08-25-2012, 12:39 PM   #10
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
Like anything else in life it takes time and practice. Just be smooth in your launch and shifting. Your times will improve over the course of the day.
Once you become consistent we can focus on specifics like how to stage to cut a better light.
Southern Comfort is offline   Reply With Quote
Old 08-25-2012, 04:06 PM   #11
73camarolt
73camarolt's Avatar
Thanks for all the advice but sadly they closed the local track with rain in the forecast so running tonight is a no go.
Old 08-26-2012, 10:30 AM   #12
Lee0123567
Nope! v6.
Lee0123567's Avatar
Drives: 2001 SOM v6
If you do wreck it though, I'll buy it.. as long as there's not frame damage.
Old 08-26-2012, 10:48 AM   #13
73camarolt
73camarolt's Avatar
I'm glad I have a back up plan haha.
Old 08-26-2012, 11:00 AM   #14
demonspeed
demonspeed's Avatar
Drives: Ordering 2017 SS
Avoid the water with street tires. If you happen to go through, just do a small burnout to dry the tires up.
Like ndtguy said, depending on the track, you'll want to start launching at a lower rpm and work your way up. My last outing I started really low and only made it to 2500. This netted me 2.0 60's on all-seasons. I could have launched higher, but 2500 was the last run I could get in that night. The launch isn't just dumping the clutch; rather, you'll want to slip a little bit. As mention, slight tire spin is better than a bog.
Shift at 6000rpm.
Shift fast
demonspeed is offline   Reply With Quote
