Old 05-28-2009, 09:00 AM   #1
LDGn63
LDGn63's Avatar
Drives: WNABEE
MIRROR - Plea for help. (updated with solution)
UPDATE UPDATE UPDATE 5/29
PIX AT BOTTOM (it almost looks like it was meant to be this way)
rolnslo, THANKS! i owe you one
Thanks so much for the re-suggestion to flip the mirror… when I had looked at it before it appeared to be a no gain but after removing the plastic wiring cover AND unhooking the wire connector from the windshield and moving it to one side, I was able to flip the mirror and tuck the onstar buttons up behind the headliner!
I just could not see the forest for the mirror (trees). I started this thread in hopes of help and I got it! (after several bruises) Thanks!
I'm estimating that this gives another inch of visibility! (which is a big percentage)
I will have pix posted tonight (need a flash).
I would still like to see a thinner mirror but this is a great improvement while I hunt!
another update: i was wrong it only gives you 7/8" more.
when measuring from the console (from the same exact spot on the console both times) and with no cameras involved the "flipped" mirror gives me 7/8" more viewing pleasure (vertically).
that is an 8.75% improvement measured vertically (i understand that nobody actually looks at a right angle to the windshield but it was the only way to measure without bias)
is this horse dead yet.... or shall we beat it some more?
thanks again to all that provided positive input.
everyone else, thanks for the laughs!
__________________________________________________ ___________
Mods, please do not merge this for it is a sincere plea that needs to stand on its own.
I need a solution to this 2SS REARVIEW MIRROR HAZARD.
edit: sorry if i wasnt clear earlier, i was a little jazzed...
MIRROR = BLIND SPOT when moving forward.
Just when I thought I had gotten used to it, I ALMOST T-boned a Prius this morning.
I would have already yanked it out of the car but I am not sure what that will do to onstar, bluetooth, and whatever other sensors may be hiding in it.
Pulled up to STOP, checked right, checked left, checked right again as I started easing into the intersection then BAM! There it was.
That darn Prius just popped out from behind that mirror like the Starship Enterprise coming out of warp… scared the KR@P outta me!
I'm goin to a dealer this weekend to try and play mix-n-match but if someone has a real solution or even a serious idea please help.
GM, if you are listening, please address this issue for ALL Camaros… now. Hey, I said Please!
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 05-28-2009, 09:05 AM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
WTF are you talking about. You are not making anysense. How would the rearview mirror make you run into a car.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-28-2009, 09:07 AM   #3
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Wow!
Hylton is offline   Reply With Quote
Old 05-28-2009, 09:09 AM   #4
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
try using side view mirrors they work pretty good i heard
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 05-28-2009, 09:10 AM   #5
IROCanSS
Drives: 89 IROC 350
I think he is saying he wants to replace his mirror with a different one but is concerned about losing the onstar??
I take it as he is not happy about the blind spot. Its the price you pay for driving this car. Try driving a corvette. In the mirror you see into the trunk, the entire top of the car and a dental floss line that is out the back window. Not to mention the side view blind spots. This aint your mommas caddy here, you have to pay closer attention and deal with the slightly obstructed view.
Old 05-28-2009, 09:10 AM   #6
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
that sucks....I've not sat in one yet, so I can not concur with this.
GMtothecore is offline   Reply With Quote
Old 05-28-2009, 09:11 AM   #7
LadiesMan217
LadiesMan217's Avatar
Drives: '10 IOM/IO 2SS/RS
He means that that rear view mirror is too large and causes a major blindspot. The Prius was directly behind the mirror (in his line of sight).
Proud Member of NEC5!
LadiesMan217 is offline   Reply With Quote
Old 05-28-2009, 09:12 AM   #8
LadiesMan217
He's not talking about backing up.
Looking out the windshield, the rear view mirror caused a blindspot.
Old 05-28-2009, 09:14 AM   #9
N6504X
Drives: 2007 F-150 KR
How tall are you? It sounds like you need to lower your seat. Wait, do they lower? Yes, I think so, it's a six way power seat. Hmmm....
N6504X is offline   Reply With Quote
Old 05-28-2009, 09:15 AM   #10
Dr Jkel
Roll Tide
Drives: 2010 2SS RJT/BLK 6Spd Man
Same thing in the Hummer H-3, just got to be more careful
Dr Jkel is offline   Reply With Quote
Old 05-28-2009, 09:20 AM   #11
jtzako
Drives: 2010 IBM Camaro SS
Are you sitting with your head touching the roof? I dont see how the mirror could cause a blind spot like that. Maybe make it harder to see something higher up like stoplights or signs, but surely not a vehicle.
jtzako is offline   Reply With Quote
Old 05-28-2009, 09:20 AM   #12
wyocamaro
wyocamaro's Avatar
Drives: 2010 2SS/RS, 2-2007 Silverados
I don't see thte issue driving mine. At 6'2" and a sunroof, I am maxed out at top, and it seems ok. remeber and spend more time.
2SS/RS, Sunroof, IOM Inside and out, Manual.......VIN 7754. 5000: DELIVERED 5/18/09
wyocamaro is offline   Reply With Quote
Old 05-28-2009, 09:27 AM   #13
JDBeck23
Drives: 2010 Camaro, 2SS/RS
I agree that the mirror is a little on the large side. But I think you need to adjust your seat/driving style to this car. The way they designed it, the exterior styling took a huge priority over practicality... as it should, it's a muscle car!
Not a bad idea to swing by the dealer to see if you can find a smaller onstar mirror. Im sure some GM cars have smaller mirrors. Let us know what you find out, it may be a common modification if we can find a plug and play replacement straight from GM.
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 05-28-2009, 09:27 AM   #14
McGruff
Drives: 98 Saturn
You obviously need to adjust your seat...you shouldn't be at direct eye level with your rear view mirror.
McGruff is offline   Reply With Quote
Need your help to come up with a navigation solution for my new Camaro! Attorneyguy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 35 03-20-2009 05:59 PM
