BeckyD @ James Martin Chevy
Old 05-28-2009, 11:31 AM   #43
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
tag thanks for the update, i haven't moved the mirror up. what vin # would this shorter mirror be shipped from factory.
thanks
joey
chopss is offline   Reply With Quote
Old 05-28-2009, 11:43 AM   #44
BLUEMARO
A Classical Greek
BLUEMARO's Avatar
Drives: DTS, Bonneville and an SS !
As time goes on we'll see these "I see no problem" members change their mind. Especially after they have a few t-bones themselves. I concur, the mirror is too large for the application. It is quite easy to miss an event because the mirror blocks a large part of the view. Out the back is not a concern, every car I've had of this nature has poor rearward visibility. Thankfully I usually drive forward. If there is a smaller mirror I'd love to have it
BLUEMARO is offline   Reply With Quote
Old 05-28-2009, 11:54 AM   #45
LDGn63
LDGn63's Avatar
Drives: WNABEE
OK.
I just went out at lunch and the top of my mirror was touching the plastic surrounding the onstar wires. I removed the plastic but the mirror wont go up any higher because of the swivelball/tube construction. (a limit that I might remedy with a dremel)
My seat is ALL the way down, the mirror is ALL the way up but blocks my line of sight.
I'll check for shorter mirrors this weekend and document any mods that I do to help those of you that need it.
Thanks all for your input and consideration to the matter.
Can anyone tell me if all of the onstar mirrors use the same plug? (it would make sense)
is the mic in the mirror?
Anybody have a wiring diagram for onstar? Hopefully the local dealer will have these but ya never know!
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 05-28-2009, 11:57 AM   #46
LSP2010
IM A GURL
LSP2010's Avatar
Drives: 2010/2SS
1100, Preliminary order accepted - 13oct08
2000, Order accepted by GM ----- n/a
3000, Order acc. by P.R---------- n/a
3100, Order available to sequence- n/a
3300, Order sch. for production--- 21may09
3400, Order broadcast------------ 28may09
3800, Order produced ------------ 2jun09(2G1FT1EW8A9114199)
4000, Available to ship
4200, Shipped--------------------9june09
ITS HERE 18JUNE09
LSP2010 is offline   Reply With Quote
Old 05-28-2009, 12:01 PM   #47
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Is it really the mirror that is causing your blind spot or is it the blacked out section of the windshield behind it?
You could also try removing the plastic wire cover between the headliner and the mirror and then relocating the metal mounting plate for the mirror higher up on the windshield.
rolnslo is offline   Reply With Quote
Old 05-28-2009, 12:09 PM   #48
Matt'sSS
From 2 door to 5 door
Matt'sSS's Avatar
Drives: C5 Vert->CGM SS RS M6->SRT8 Magnum
Speaking as someone who is 6'6", and had to order my car without a sunroof so I didn't have to drive laying down to avoid constantly rubbing my head... The visibility with the mirror was concerning in both of the cars I sat in. Something will have to be done for the car to be safe, so hopefully GM can help us find a better solution.
In my other sports cars (Corvette included) I -always- bend the mirror as far up as possible, either the ball joints wont go any further, or it hits something above it.
In the Camaro the plastic wire cover above the mirror severely hinders this (see picts below). If GM could make a much thinner wire cover that may do the trick, otherwise I may be removing it completely (the plastic cover) to see if that does the trick.
IMHO, having on-star to use is great for emergencies, but not if it's attached to the mirror that is so big & in the middle of the windshield that it actually causes the accident...
From your other thread...
Originally Posted by LDGn63 View Post
pix... might try to remove that plastic cover hiding wiring on the windshield...
Matt'sSS is offline   Reply With Quote
Old 05-28-2009, 12:11 PM   #49
Matt'sSS
Matt'sSS's Avatar
It's the mirror. The blacked out section looks big, but it's angled with the windshield & further away from your face. When you look at it (or at least when I look at it from my seating position) you see the mirror, no black under it, just behind it.
Old 05-28-2009, 12:22 PM   #50
Speedfreak
Drives: 1999 30th Anniversary Trans Am
Originally Posted by Joe in T.O. View Post
Just remove the mirror. "What's behind you is not important"
Probably just a mustang anyway
Speedfreak is offline   Reply With Quote
Old 05-28-2009, 12:26 PM   #51
AGM76
Drives: 1995 z28 - 2000 SS - 08' vette
got some x and y dimensions on the mirror frame?
AGM76 is offline   Reply With Quote
Old 05-28-2009, 12:30 PM   #52
GTAwheelman
Drives: 1985 Camaro Sport Coupe
at first i was confused on how this could be a problem. then i remembered i had this problem with my 3rd gen once. now i lean back more.
GTAwheelman is offline   Reply With Quote
Old 05-28-2009, 12:36 PM   #53
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
How about tilting the seat back a little. What would you see?
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 05-28-2009, 01:14 PM   #54
snsdiver72
IPA in Iraq
snsdiver72's Avatar
Drives: Traverse, Titan, Crown Vic PC
Send a message via Yahoo to snsdiver72 Send a message via Skype™ to snsdiver72
i mean, the thing physically LOOKS HUGE (IMHO) but I wouldnt care so much if I could see thru it.
Well then it wouldnt be a mirror unless it was mounted between walls one side for the bad guy and the other for the cops looking at the bad guy
snsdiver72 is offline   Reply With Quote
Old 05-28-2009, 01:56 PM   #55
rusty73
Drives: 2010 Camaro, SS, Cyber Gray
Originally Posted by Scott@Bjorn3D View Post
WTF are you talking about. You are not making anysense. How would the rearview mirror make you run into a car.
I agree with Scott.
Scott, we'll be keeping your daughter and your family in our prayers.
rusty73 is offline   Reply With Quote
Old 05-28-2009, 02:04 PM   #56
LDGn63
LDGn63's Avatar
Drives: WNABEE
3 5/8" top to bottom
9"ish side to side
Why oh Why?
Need your help to come up with a navigation solution for my new Camaro! Attorneyguy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 35 03-20-2009 04:59 PM
