BORLA
Old 08-25-2012, 02:16 PM   #1
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
Rear end wiggling on moderate-hard turn
Any thoughts on how to correct rear end wiggle on turns? On what I would call a moderate turn (a safe but spirited 30-35mph on a two lane turn in the left lane) the rear end wiggles very hard and makes the car feel almost out of control...
Any insights are appreciated.
Falundir is offline   Reply With Quote
Old 08-25-2012, 04:00 PM   #2
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
Might not be the car. Crossing a small but abrupt change in road contour will make a stiffly-suspended car move around more, especially under moderately enthusiastic acceleration. Putting the left side wheels over on the other side of the road crown might even be enough.
I happened to encounter this particular condition a couple of hours ago.
Norm
Norm Peterson is offline   Reply With Quote
Old 08-26-2012, 09:10 PM   #3
kbui
kbui's Avatar
Drives: 85 Vette, 07 Escalade ESV, 03 GMC,
Not enough tire for the power level you are running? Even with similar suspension mods as yours, coming out of a turn in 2nd or 3rd, I have to be very careful with the right foot on the OEM 275 rear tires and perfectly smooth road.
ADM Performance installed and tuned: Maggie, Stainless Works Power LTs, ADM race cai, ADM ZL1 scoop
Whiteside Customs Super Street 2 Package w/ coilovers
BC Racing Coilovers and lowered, Whiteline Bushings & Swaybars
MBRP catback exhaust, ZL1 bumper conversion, Drake billet shifter, Hurst paddles, NLP rear spoiler, OEM GFX, Vis Racing hood, ASA GT5 wheels
kbui is offline   Reply With Quote
Old 08-26-2012, 11:14 PM   #4
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Upgrade the bushings. Maybe your sway bar is set to stiff. Can try those to see if it helps.
Inferno LSX is offline   Reply With Quote
Old 08-27-2012, 02:17 AM   #5
Rob@WretchedMS
Drives: His Wife Crazy
do you have an alignment print out?
Check the bolts in the rear to be sure they are tight, including the cradle.
does this happen when you cross the center of the crown in the road?
If it is, then it's possible that you have to much rear camber, and the 'grip' is changing from side to side.
Rob@WretchedMS is offline   Reply With Quote
Old 08-28-2012, 12:18 AM   #6
Falundir
Falundir's Avatar
Thanks all. I'm about to make an appointment with a top notch alignment shop that does cars like ours. The rear is starting to creak when I get in the car (I'm heavy but not THAT heavy), so I'm thinking I have a few loose bits...
Old 08-28-2012, 08:49 AM   #7
kbui
kbui's Avatar
I have gotten the sway bar end links' bolts coming loose a few times as well as the collars on the old sway bar that caused the "wiggling". You might just want to craw underneath to check them out before take in the car.
