Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 08-25-2012, 07:08 PM   #1
spyderbuddy's Avatar
dianogstic code p 0497
P0496 EVAP Flow During Non-Purge Condition
OBD-II Trouble Code Technical Description
EVAP (evaporative emission) Flow During A Non-Purge Condition
What does that mean?
The P0496 DTC code is a generic code which applies to all vehicle makes. A quick search on the 'net shows that this code seems to be more common with GM (Chevy, Pontiac, etc.) vehicles. In Acura, Honda, Hyundai, Kia, and Mazdavehicles, this code is described "EVAP system high purge flow" which is the same thing.
This DTC checks for undesired intake vacuum flow to the EVAP system. The control module seals the EVAP system by commanding the EVAP canister purge solenoid valve OFF and the EVAP canister vent solenoid valve ON. The control module monitors the fuel tank pressure (FTP) sensor to determine if a vacuum is being drawn on the EVAP system
If vacuum in the EVAP system is more than a predetermined value within a predetermined time, this code is set and the MIL (malfunction indicator lamp) is illuminated.
Symptoms of a P0496 DTC will include MIL illumination, and most likely no other noticeable symptoms. Some may experience a hard start / crank condition. In some cases the engine may run rich which may not detected, but can cause damage long-term (think: catalyticconverter damage).
Potential Causes
Potential causes of a P0496 EVAP code include:
  • <LI itxtNodeId="56" itxtHarvested="0">Faulty purge or vent solenod/valve <LI itxtNodeId="55" itxtHarvested="0">Plugged EVAP canister <LI itxtNodeId="54" itxtHarvested="0">Failed EVAP / fuel pressure sensor <LI itxtNodeId="53" itxtHarvested="0">Poor electrical connection <LI itxtNodeId="52" itxtHarvested="0">Short electrical circuit condition (Hyundai, Isuzu) <LI itxtNodeId="51" itxtHarvested="0">Faulty canister purge valve <LI itxtNodeId="50" itxtHarvested="0">Blocked vapor canister <LI itxtNodeId="49" itxtHarvested="0">Faulty vent solenoid <LI itxtNodeId="48" itxtHarvested="0">Leaking EVAP system hose (Hyundai)
  • Faulty purge flow sensor (Kia, Mazda)
First Question, Is this covered under the 100,000 mile warnety
Second Question, Can I do this myself if I have to.
Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
