Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 08-26-2012, 05:36 PM   #1
Loving my CAMARO!!!
EPCamaro's Avatar
Drives: 2013 2LT RS CRYSTAL RED
******** Adaptors and CDT Audio
For those of you who have experience in installing the doors..I need a little help. Getting ready to order my speakers for the doors. I use CDT Audio for years and love the SQ.
IF I order the ******** Speaker Adapters and use (one of my choices) a M6+ 480 6.5 or ES-06 the Euro/HD versions will they be able to fit. Here are there parameters:
M6+ regular
  • Diameter: 6.5"
  • Sensitivity: 83.9dB
  • Maximum Power Handling: 300 Watts Peak
  • Nominal Power Handling: 150 Watts RMS
  • Frequency Response: 10~4000 Hz
  • Nominal Impedance: 4 Ohms
  • Voice Coil Diameter: 1.5"
  • Peak Xmax: 15mm
  • Magnet Weight: 30 OZ
  • Surround Material: Rubber
  • Frame Type: Cast Alloy
  • Mounting Depth: 3.37" (top mount)
  • Cutout Diameter: 5.812"
  • Overall Outer Diameter 6.81"
or the
ES 06
1 pr 6.7” extended bass mid woofer
Technical specs and contents:
  • Frequency response 10Hz-4000Hz
  • Power handling:100WRMS (200Watt Pk).
  • Impedance 4 Ohm Sensitivity:89dB
  • Mounting depth: 2.9”
  • Cutout diameter: 5.87”
  • Cast frame: OD 6.7”
  • Cone: Mix/Kevlar/Fiber glass
  • Magnet weight 30 Oz
  • Cone surround Buytal rubber
  • Impedance: 4Ohm
  • Fs: 55Hz
Want to make sure they will fit or get a good idea it they will. Any installers out there or ******** help would be appreciated!
EPCamaro is offline   Reply With Quote
Old 08-28-2012, 02:54 PM   #2
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
I'm using ******** front speaker adapters for my CDT HD-642DT front set. I'm using the 5.75" cut out in the adapters for my drivers, but the ones you listed would need to have the 6.0" cut out in the adapters.
My speakers are 6.5" with a 2.75" mounting depth.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
adaptor, audio, doors, speakers
