08-27-2012, 05:31 PM | #1 |
Drives: 2012 camaro SS RS 6.2L LS3 Join Date: May 2012
MSD 2 step launch controller PN8733 NEED HELP PLEASE
hey i have a question.. I have a 2012 camaro with the ls3 and i just got the PN 8733 msd 2 step launch controller.. i have it installed but am having trouble trying to figure out what wire to hook the activator wire to the clutch switch. the clutch switch has 3 wires but im having problems figuring out witch one i need to use and is 12V or ground when i push it in.. it tried just putting it to ground so it would always be on but it only lets the car go to the 3,000 RPM that i set while im driving too so it cant work that way.. just thought u might be able to help me.. its greatly appreciated
08-27-2012, 05:44 PM | #2 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
I have mine run to ground with a momentary switch. Set your RPM, then hold the switch to activate, bring your RPM up... release it and away you go.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
08-27-2012, 06:05 PM | #3 |
08-27-2012, 06:42 PM | #4 |
If the track is really hooking I set mine @ 2K. I have tons low end power so anymore RPM's and I'll blow the tires off.
08-27-2012, 07:07 PM | #5 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
I launch at 3900 almost all the time... 2K and I would bog like no other must have something to do with the tune...
08-28-2012, 10:23 PM | #6 | |
Thread Tools | |
