Old 08-27-2012, 08:56 PM   #1
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
315 Square Setup
What would it take to run 315/35R19's on all four corners?
Edit...
Whoops, posted in wrong sub forum. Mods, please move to wheels&tires.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 08-27-2012, 09:26 PM   #2
600hp-lpe
Drives: 2010
I run 315/35/18 hoosier's on the front.. they stick out 1"
19" will hit the fenders on the street
600hp-lpe is offline   Reply With Quote
Old 08-27-2012, 10:02 PM   #3
Avalnch
Avalnch's Avatar
I was hoping 19's would fit cause I drive out to my local events and am concerned about ground clearance.
What size 18" wheels do u run with your Hoosiers, if I may ask?
Old 08-28-2012, 12:07 AM   #4
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Dan is spot on. We are running 305/35/20s on the L/28 from Lingenfelter and that rubber just clears. We have found that the sweetest setup is 305/30/19s, unless you go to slicks like Dan has in the 18" range.
Old 08-28-2012, 05:51 AM   #5
600hp-lpe
Drives: 2010
my tire sizes are in my signature.
wheel sizes are 18X11.5 front, 18X12.5 rear, made by CCW.
The 18's take a lot of work to fit, and are not recommended for street duty. With the short profile (25.6.height), they don't hit the fender.. but will hit the lower control arm, e-brake cables, and up front, hit the knuckle for the camber adjustment. All of these areas need to be modified to run wide 18 wheels.
What will fit your car on the street is a 19X10.5 with 305/35/19's.
I run 19X10 with 285/35/19 on the street (also my rain tires for autocross).
I went skinnier than the 305's for better wet traction, as i have the 18" slicks for dry.
Old 08-28-2012, 07:27 PM   #6
Avalnch
Avalnch's Avatar
I can't believe there's no room to squeeze 315's up front (how bout on a 10" wide rim?). 305 is oh so close, but Hoosier doesn't make a 305/19 in any aspect.
Old 08-28-2012, 09:22 PM   #7
JusticePete
VIR Specialist
Rim width is critical in terms of handling a smaller tire stretched a bit tighter across the rim will handle better than a wider tire in a relaxed fit across a minimum rim width.
Old 08-29-2012, 12:11 AM   #8
Avalnch
Avalnch's Avatar
That's a great point, Pete. I was hoping someone out there has successfully fitted 19x11" rim up front for 315 Hoosiers. 315s out back is definitely no problem.
Old 08-29-2012, 10:35 PM   #9
JusticePete
VIR Specialist
I don't know of anyone running a 19x11, but I am quite sure Dave Schardt at Forgeline could do it.
Old 08-30-2012, 12:18 AM   #10
Avalnch
Avalnch's Avatar
Thanks, Pete. I'll definitely be having a chat with Dave.
Old 08-30-2012, 10:27 PM   #11
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You can do it easy, but they will stick out.
SUX2BU is offline   Reply With Quote
Old 09-05-2012, 12:25 AM   #12
JHart
I haz camaro again :)
JHart's Avatar
Drives: 2010 Chevrolet Camaro 1SS
i wonder what wheel offset and width would be needed to fit a 305/35/20 up front? that filled out look would look amazing.
2010 Camaro 1SS(back in a camaro again, yessssss!)
2010 silverado z71 ccsb(sold, old dd)
2010 camaro1ss(sold, missed, will have another someday)
JHart is offline   Reply With Quote
Old 09-14-2012, 04:52 PM   #13
Avalnch
Avalnch's Avatar
Well, I had a chat with Dave Schardt at Forgeline and he says that a 19x11 with 315's is doable. This is preliminary and I'd be more comfortable talking to Dave some more and having him review the combined tire & wheel combo, but I am optimistic.
Old 09-14-2012, 05:21 PM   #14
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
I'm running a set of Forgeline GA3R rims 19" on my car, I fit a 305 up front. You could get a 315 up front, but will have to double check, as it might not clean multiple parts like 600lpe mentioned.
Let us know what Dave says.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
