sjm autoprod
Old 08-27-2012, 09:16 PM   #1
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
Suspension advice!!!!
2 days ago got the ZL1 rear sway bar install, change link and lower arm...
after i secure the bar, i notice that to tide the links on the passenger side i push down the bar and the driver side i pull up to install the link...
my question for the experts:
1) after change the lower arm do i need alignment?
2) how much i have to tide the links?
PS: Can somebody with a 2012 suspension post a photo to see if i did everything right... maybe is just me but the car feels kind of weir when i drive it... TIA!
Monchy36 is offline   Reply With Quote
Old 08-27-2012, 09:24 PM   #2
Monchy36
Monchy36's Avatar
I thanks nak3dsnake for looking into to help me out! here are some photos of my links...
Old 08-28-2012, 12:19 AM   #3
JusticePete
5th Gen Master Builder
JusticePete's Avatar
Drives: Camaro Justice
Aside from having the nuts on the bottom of the droplink stack (which will not hurt anything) you have most likely done the job correctly. If all four bushes on each droplink are making good contact with no air gaps the nuts should be tight enough. From the looks of the picture I am thinking you need a couple of turns.
The rear lower inner bolts are your camber eccentrics so the best case scenario is your alignment would be close to right if the eccentrics have been indexed to a painted mark and even then I would highly recommend an alignment.
Old 08-28-2012, 12:52 PM   #4
Monchy36
Monchy36's Avatar
Thank you JP for you reply! What's the worst case if i wait to get my lower springs to be install so i can aligment? Not going to have it for a couple of weeks...
Old 08-28-2012, 12:56 PM   #5
JusticePete
How many miles will you drive between now and your alignment?
Old 08-28-2012, 02:48 PM   #6
Monchy36
Monchy36's Avatar
I'll said 300+....
Old 08-28-2012, 04:39 PM   #7
JusticePete
Originally Posted by Monchy36 View Post
I'll said 300+....
If your wheels don't appear to be pointing out or in (toe) and you avoid burnouts and aggressive driving you should be OK. If your tires are already worn OK may not last 300 miles.
Old 08-28-2012, 04:52 PM   #8
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
+1 Good point there. Couldn't agree more.
ModBargains.com is offline   Reply With Quote
Old 08-28-2012, 05:06 PM   #9
Monchy36
Monchy36's Avatar
I tide the links like you said and improve a lot! Tires are straight! But i'll do the aligment!
