Old 08-27-2012, 10:21 PM   #1
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
Let's see your 1/4 mile times!
My best is a 12.9
60': 2.1 (not the 12.9 ET 60')
Mods: ARH LT's, CAI, custom tune, Trailing arms
I'm not sure why I am not hitting around 12.6 like others. Bad wheel hop when hitting second. Confuzzled. Only runs have been made this summer so I'm sure the heat and humidity have an effect. The 2.1 60' was made at Darlington Dragway, SC which is 155 ft above sea level, but was around 70 degrees and over 90% humidity which got me 13.0 best. 12.9 was made at Fayetteville Motorsports Park, NC and was around 90 degrees, humidity was alot lower, and 100 ft above sea level 60' besting around 2.3.
Frid is offline   Reply With Quote
Old 08-27-2012, 10:23 PM   #2
Supercharged SS
Drives: 2010 Camaro
Originally Posted by Frid View Post
My best is a 12.9
What's your mph?
Old 08-27-2012, 10:23 PM   #3
Frid
Frid's Avatar
It's either been 109-110, 110 being the highest
Old 08-27-2012, 10:26 PM   #4
Supercharged SS
Drives: 2010 Camaro
That's low for the parts you have. You'll see 113 in the fall and get your mid 12 no problem.
Old 08-27-2012, 10:28 PM   #5
Frid
Frid's Avatar
. I find myself having to shift into second around 4800-5000 because if I don't, hello horrible wheel hop. And yeah, I can't wait for the fall!
Old 08-27-2012, 10:52 PM   #6
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
My personal best is 12.800 with a 1.92 60ft. on p-zero's @ 109.85 mph but that was during the heat wave
we had this summer.Looking for better times this fall.Going to try my 18" M&H drag radials
when I go back to the track.Also I have added the ADM scoop to go with my cold air intake.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 08-27-2012, 10:57 PM   #7
Mikey193
Mikey193's Avatar
Drives: 2012 black ss/rs camaro
I'm 335. That's on a bone stock ss m6, I need to work on getting it to hook. And I agree on the wheel hop when shifting into second I got that a couple times :(
Mikey193 is offline   Reply With Quote
Old 08-27-2012, 11:22 PM   #8
Neumatic
Neumatic's Avatar
Drives: 2010 Camaro 2SS M6
Each on seperate runs, really need to work on my 60' time.
RT: .000
60': 2.200
1/8mi:8.945 @ 82.61 mph (8.948 @ 82.96 on same pass as 1/4)
1/4mi ET: 13.545 @ 108.56 mph
Neumatic is offline   Reply With Quote
Old 08-28-2012, 12:12 AM   #9
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
11.37 @ 126 reaction time on this run was a .433 and 60 s was a 1.93 on this run .made this one starting in 2nd ,by the end of 8 passes later I also got an 11.3 using first to start.definately need practice
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 08-28-2012, 12:45 AM   #10
blufin
blufin's Avatar
Drives: Fire Engine
I found that when running on the Pirrelli's, once the tire has lost more than 50% of its tread, I start to get the wheelhop on 1-2 shift as well.
Best runs in sig.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 08-28-2012, 09:11 AM   #11
Mikey193
Mikey193's Avatar
Best runs in sig.
The 12.6 run. Was that on street tires, or drags?
Old 08-28-2012, 09:42 AM   #12
blufin
blufin's Avatar
Drives: Fire Engine
Stock Pirelli's at 32 lbs
Sold
Old 08-28-2012, 09:50 AM   #13
Mikey193
Mikey193's Avatar
That's a good time. My goal is to try and hit 12.9 next time I go to the dragstrip
Old 08-28-2012, 12:27 PM   #14
Frid
Frid's Avatar
Best runs in sig.
Same here. Only one side of the car gets alot of rubber too. Guess its the way the engine torques. And yes the wheel hop is bad :(
