View Poll Results: Would you buy a Recaro/ZL1 brake package for the SS/1LE?
Yes. 57 93.44%
No. 4 6.56%
Voters: 61. You may not vote on this poll
Old 08-27-2012, 09:42 PM   #1
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Question Recaro/ZL1 brake package for 1LE?
Just wanted to see how many people would be interested in purchasing a package like this. If offered the way I would do it, it would be a package added to the SS and separate from the 1LE pcakage itself but would require ordering 1LE. That way the great value of the 1LE would remain intact but a little extra could be offered to those that want it.
Old 08-28-2012, 07:16 AM   #2
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Hell yeah. I can't understand why it's not.
1977and2010 is offline   Reply With Quote
Old 08-28-2012, 11:37 AM   #3
DanSS24
DanSS24's Avatar
Drives: Dream Cars in my head
Now that would be real awesome.
Wishful thinking...but I sure can dream big.
DanSS24 is offline   Reply With Quote
Old 08-28-2012, 12:50 PM   #4
scottyvegas
X SS
scottyvegas's Avatar
Drives: 2010 Camaro 2SSRSM6 1988 Sportside
yes
MODS: PEDDERS XA COIL OVERS, STAGE 3 CAM, McLEOD CLUTCH, SKIP SHIFT, , HURST SHORT THROW, CAI INTAKE, SCOOP, WASHER RELO KIT, KOOKS HEADERS, KOOKS HI FLOW CATS, CUSTOM TUNE, QTP CUT OUTS, PAINTED STRIPES, PAINTED SS EMBLEMS, PAINTED FIN, PAINTED REAR TAIL LAMP BEZELS, HERITAGE GRILLE, DUCTS, AAC STUFF, BAER ROTORS, HAWK PADS, FUZZY DICE, LASER BEAMS, DISCO BALL, SYBIAN & 3 CHROME VALVE STEM CAPS................
scottyvegas is offline   Reply With Quote
Old 08-28-2012, 12:57 PM   #5
Kent2010
Drives: Camaro SS
Price, price, price-- as always.
For $1999 -- it would be a very popular option for ALL SS Camaros.
For $2999 or more -- not so much.
Kent2010 is offline   Reply With Quote
Old 08-28-2012, 06:34 PM   #6
PYROLYSIS
PYROLYSIS's Avatar
Agreed. If this package followed the great value of the 1LE $2000 would be a reasonable price. The type of customer that wants the 1LE would definitely add this for the right price.
Old 08-28-2012, 07:39 PM   #7
monstertodd
monstertodd's Avatar
Is it possible to put the CTS-V recaros in a Camaro?
Old 08-28-2012, 10:53 PM   #8
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
The 2013 Mustang GT offers the Recaros for $1200 according to a guy I met at the track this weekend. His car had 4 piston Brembos in the front. I didn't ask if that was part of that package. I know his car was stock.
The seats were really nice.
bannonm is offline   Reply With Quote
Old 08-29-2012, 06:23 PM   #9
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
The zl1 brake package is very heavy, so probably wouldnt pay for extra weight. However, the 1le should ve been lighter for the stock brembos.
Recaros, $1500 or less, yes i would ve bought them, and they would be lighter.
Anyhow, I aplaud GM fir making it as cheap as possible, and i wish they wouldve taken more stuff out and make it cheaper. Hood, trunk acoustic Treatment, engine cover, sun visors, tire pump, fog lamps, badges, anf 19" rims would ve been perfect.
Mgizzle is offline   Reply With Quote
Old 08-31-2012, 10:03 PM   #10
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
I wouldn't say the ZL1 brake package is "very heavy". Unless I'm mistaken, the front rotors, while larger, only weigh 1lb more than the SS rotor. I can't find the thread with all of the rotor and caliber weights. But a safe assumption would be 2-3lbs more for each front wheel. So 4-6lbs total for a better braking packaging.
In any case, depending on the actual look of the seat (I want them to look and feel good...I'm not just buying a brand name), yes, I would add the package in a heartbeat.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 08-31-2012, 10:29 PM   #11
JusticePete
Wrote the 5th Gen Book
JusticePete's Avatar
Drives: Camaro Justice
Yes sir.
Old 08-31-2012, 10:36 PM   #12
JusticePete
SS all iron
ZL1 Iron ring Aluminum Hat
The rotor weights are the same.
The rotors are very different up front. These are dual cast from Brembo with an aluminum hat / center and iron rotor. Even though the new Cadillac rotors are larger and thicker, they weigh the same as the OEM SS Camaro rotors.
The ZL1 two piece setup should be a bit lighter than the CTS-V dou-cast.
Old 08-31-2012, 10:59 PM   #13
monstertodd
Yes sir.
Pete what all is involved with this swap?
Sent from my abacus using precise finger movements......
Old 08-31-2012, 11:08 PM   #14
JusticePete
This.
Pedders is committed to being a strong supporting member of the 5th gen community. When we needed a brake upgrade for our Camaro we looked everywhere and came right back to the GM parts bin. It took a while, but we sorted it out and found what we believe to be the most cost effective and perhaps best brake solution for the Camaro. If I ran GM -- and I don't I know what I would do for better Camaro brakes. I would use THE CADILLAC OF BRAKES for the Camaro -- CTS-V BRAKES.
These are the same brakes that set a record on the Ring with John Heinricy behind the wheel of s CTS-V as the fastest production sedan to run the ring.
The CTS-V is a bit heavier than the Camaro making the setup PERFECT. This is a bolt on project that requires only the front dust shield be trimmed to fit the over-sized six piston front caliper. Everything is performance / track ready to go. The pads are perfect out of the box. They are also Cadillac quiet. The front calipers do require different bolts. All the parts are supposed to be available front the GM parts bin, but we did have some delays in collecting everything we needed. Arthur at Witt Buick Pedders did a great job of getting all the bits pulled together for me.
This is a HUGE upgrade for the Camaro. Take a close look at the calipers and pads. The superior clamping from six pistons combined with a much larger pad and rotor work to PERFECTION with the master cylinder and computer.
Trimming the front dust shield was straight forward. How can any modification (unless it is Pedders made to fit just like the OEM bits we replace) be complete without sparks from a cutting wheel?
The brake upgrade is 100% OEM CTS-V with the exception of Pedders Camaro Brake Lines. You can see our brake lines fit and mount just like OEM. Why is Pedders doing brake lines for the 2010 Camaro? Great question. When we built our Camaro we couldn't find them in the aftermarket so we took matters into our own hands. PDUSACAM2800 https://secure.merlinsoftware.com.au...0&Featured=Yes
The rear Cadillac CTS-V caliper is the same as the Camaro SS rear caliper. The only difference is color. We did try to rear CTS-V and found the hat offset is a bit different, but the OEM Camaro SS rotor is a perfect match.
Here they are, THE Cadillac of Brakes of the 2010 Camaro.
Rear Before
Rear After
Front Before
Front After
When you do a conversion like this it is critical that the entire brake system be bled including the ABD computer. We connected the new USB based GM scan tool and could not find a full bleed program. We connected a Tech I scan tool, selected 2010 Corvette and found a functional solution. With everything completed we did on more safety check and went out for a road test. Working with Witt Buick Pedders means we have access to everything we need including a 'private' area to bed the brakes. 60 to 20, 80 to 20 and 100 to 20 and the brakes are bedded.
How do they feel -- jut like a Cadillac CTS-V. Are they better than the SS brakes -- OH YEAH!!! Now the tough question, how do you get a set. We are posting this for the benefit of the Camaro community. Witt Buick Pedders put in a tremendous amount of effort to secure all the bits and do the install. Little things like finding the right way to bleed the brakes take a lot of time. The rear rotors from the CTS-V don't fit and son on. They have earned the right to at least have the opportunity to make a parts sale.
Keeping the community in mind, you already know that a complete set of CTS-V brakes will fit and what you need to order short of the parts list. Your creative and can source that on the Internet. If you would like to order a turn key kit you can call Bruce Raymond at Raymond's Performance. He powder coats the CTS-V calipers to match the SS rears and machines slots into the rotors for increased performance.
Raymonds Alignment
3828 Clarks Creek rd
Plainfield, IN 46168
bruce-raymond@sbcglobal.net
O (317) 838-7112
