ADM PERFORMANCE
Old 08-28-2012, 12:37 AM   #1
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
2 tenths for $1,000-$1,500?
Any suggestions from the guys that know these cars best?
I told myself I would not spend any more cash this year, but you know how that goes....
I am looking for something that will gain me a consistent 2 tenths. I have a couple ideas, but your suggestions from first hand experience would be greatly appreciated.
Current setup:
Stock block/ Stock Cam/ Heads/ etc
TVS2300 running 3.2 pulley on 7psi boost (Track is at 5253ft above sea level) - ribbed pulley and gator belt doesnt appear to have any slip, but I guess I could be wrong?
Doug Thorley 1 7/8 longtubes W/ cat delete
Noweeds diverters and Corsa Exhaust
Snow Meth kit
Linelock
17" Bogarts on rear W/ M&H drag radials (325's) - running 22" TSW's in the front.
Everything else is stock I believe.
Best time is 11.9@114mph
Consistent 12.1@113mph
consistent 1.7xx 60'
Car put down 608rwhp/ 597tq but these are corrected #'s for elevation. I'm sure actual is much lower.
Here are a couple of my thoughts:
1 - short throw shifter, trailing arms, sway bar
2 - Skinnies for the front (might be more than my budget?)
3 - overdrive for maggie to up the boost and trialing arms
4 - Gears? maybe the new LE1 gears? maybe get a short throw as well.
I am really leaning towards skinnies just because I love the look, but I have a feeling front rims/ tires wouldn't gain me .2?
Any and all suggestions would be great.
AngelSpeedFreak is offline   Reply With Quote
Old 08-28-2012, 12:55 AM   #2
linehand7
Drives: 03 duramax 01impala 2010 2ssrs
best bang for the buck would be a smaller pulley and a second tune (may need a programer so you can switch back and forth on your tunes) at 7 pounds of boost you can go with a smaller pulley. if you can switch tunes (with a programer , you can also have a tune with 110 race fuel.) and you won't spend more than you want.
linehand7 is offline   Reply With Quote
Old 08-28-2012, 01:09 AM   #3
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
Wow elevation sucks lol. Most stock ss's trap in the 110 range at lower altitude.
Oxtar41 is offline   Reply With Quote
Old 08-28-2012, 09:48 AM   #4
AngelSpeedFreak
This is a definite option. One thing I will need to look at is my injector status as I may be close to max on that and my stock fuel pump. I wont be able to go a smaller pulley up front as it's already a 3.2 but I could buy an overdrive for out back then possibly go up a little in the front to gain another 2-3 PSI pretty safely.
I do have an SCT handheld that came with my maggie but I've never used it. My tunes were done via a shop who used HP Tuners. I could probably get them to save both tunes on my SCT though?
Thanks for the suggestion
You don't have to tell me about it. I hate coming on here and seeing how cars with longtubes are at my same numbers Stock SS' run about a 14.2 up here at around 95mph. DA is always between 7000-9000.
Old 08-28-2012, 02:21 PM   #5
AngelSpeedFreak
Originally Posted by HRD_WRK View Post
Gotta ask
I assume the maggie isn't hooked up to a stock air box - you didn't specify- else >0.2 gain with CAI and scoop.
I assume you air up the fronts above cold psi 'unofficially' to run-lower roll resistance.
17" Bogarts and M&H shinnies up front (weight in at ~36 lbs ea set if I recall)-great weight loss. Good start for diet-see diet list-'lose the weight/lowerthe time' for easy temporary or permanent items.
Trail arm / cradle bushing
Torq conv - 0.4 estm generally by Tracy (user SC1250)
Tim
Thanks. Forgot to mention the Rotofab CAI
I really wish I knew if the skinnies would give me any actual gains? I realize the weight difference between the Skinnies and my 22's is probably about 45lbs each. I guess that could be close to a tenth right there?
no torq cov as I am M6... Thinking maybe a short throw might gain me a bit?
Old 08-28-2012, 03:16 PM   #6
AngelSpeedFreak
Thanks for the suggestions. It's little stuff like removing the washer bottle that could lead to a small enough gain that I am looking for..
Old 08-28-2012, 05:55 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Sux2bu has posted various wheel/tire combo weights a few times, I'd think that skinnies would drop off some weight and help overall. I think you'd see improvement also reducing rotating weight and the front skinnies would have less drag. These tanks are heavy, any weight reduction is a good idea.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-28-2012, 06:17 PM   #8
Synner
Drives: 2011 2SS/RS M6
I would do gear and skinnies to stay in your budget. What gear and rpm are you crossing the line at now? Don't go too steep and force another shift. And what rpm are you leaving the line at? Drag shocks would help if its purely a race car.
You'd need cam/fuel pump/injectors/cog drive/tune to get more out of the motor.
Synner is online now   Reply With Quote
Old 08-28-2012, 06:32 PM   #9
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
Do you have stock Maggie injectors and fuel pump? OD cog is definately the way to go. You have a good 60ft time so I would go after more hp.
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 08-28-2012, 06:47 PM   #10
AngelSpeedFreak
I'm sure skinnies would help, I just havent seen any actual numbers to see if that would gain me .2 or not. Hate to spend all my loot on them and have zero gain.
Crossing the line in 4th barely. I shift into 4th at almost the line, sometimes I hit rev limiter in 3rd as it is just that close.
I launch at 3800rpms.
Cam/Pump alone would be out of my price range that I want to spend I think.
stock injectors and pump.Think the OD and running 9-10 psi would be possible with stock fuel?
Old 08-28-2012, 06:55 PM   #11
Synner
Then you definitely need gear. 3.91 would probably be just right when the 1LE crap is easier to get. I refuse to fall for the lingenfelter price gouging. And it would help make up for the poor DA a bit versus the motor work expense.
Old 08-28-2012, 08:12 PM   #12
Ryan@Lingenfelter
Ryan@Lingenfelter's Avatar
Drives: 1998 Camaro Z28
I think a set of gears would definitely be a step in the right direction. Our gears are made by the OE manufacturer. They have a tried and proven track record and we have them in stock, ready to ship. PM me if you have any questions.
Ryan
Ryan@Lingenfelter is offline   Reply With Quote
Old 08-28-2012, 08:35 PM   #13
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Are you putting down 608rwhp/597rwtq on stock suspension? If so you could easily see .2-.5 with a few suspension upgrades alone. Shoot me a PM if you would like to discuss it.
Old 08-28-2012, 08:41 PM   #14
Supercharged SS
Drives: 2010 Camaro
With an M6 I hope he's not on a stock suspension! But I'd like to know how I can get .2-.5 with a few parts. Share some ideas. Hook a brother up!!
