Old 08-28-2012, 10:39 AM   #1
Rizzo
Drives: 2012 Camaro ZL-1 SIM
ATTN Scosche Users
Hi all,
I am troubleshooting an issue that seems to be related to a Scosche kit install on my 2012 ZL1. I had posted an earlier thread related to an "electrical gremlin" and was able to narrow it down to the Scosche kit install.
I have had three other members PM me with similar issues, so I want to see if there are others seeing issues with their Scosche kit.
Here are my issues:
Issue #1:
Both of the key FOB would only work when I was within 8 feet or so of the car. Page 2-3 says it should be 65 feet. I changed the battery on both FOBs and the issue persisted. The FOBs were also replaced. Here is a video showing the issue
Issue #2:
I programmed my Universal Remote System to work with my garage door. This is also a feature I had on my 2010 Camaro SS. The signal of the URS is limited to approx. 8 feet from the antenna of the garage door.
Issue #3:
I intermittently receive an alert for the tire pressure monitoring system. Both rear tires sometimes lose signal with the vehicle. The reading was displayed as “—“
Issue #4:
Sometimes when opening the trunk with the FOB, the locking mechanism engaged twice. (Unlock then lock). This prevents the trunk from latching closed. I have to hit the FOB again to unlock the latch before it would close.
Issue #5:
The "auto door unlock" settings always default back to "driver door" once the menu is exited.
When the Scosche kit is disconnected from the car, issue#1 immediately goes away. Issues 2,3,and 4 have not reoccured after two weeks of waiting.
As best as I can tell:
It appears that the Scosche kit is sending some sort of signal down the communication bus that is interfering with the "Remote Door Lock Controller Module" (RDLCM) via the Body Control Module (BCM).
Are any other Scosche users having weird electronic-like issues?
Rizzo is offline   Reply With Quote
Old 08-28-2012, 01:27 PM   #2
Wuiquen
Wuiquen's Avatar
Drives: 2011 Summit White 2LT/RS
This is exactly why I am still skeptical about changing my radio... I have the stock one and the sound of it. but man, most people seems to be having issues with all the kits.. either the kits mess with the car systems or the kits arent really reliable.. All I want is to keep my back up sensors but have aftermarket stereo and speakers..
Wuiquen is offline   Reply With Quote
Old 08-28-2012, 02:04 PM   #3
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
I have Issue #1 and Issue #3. Issue #1 doesn't really bother me so much, but #3 happens almost every time I drive it now, though only on the rear passenger side wheel.
Issue #3 only showed up after I unmounted the kit to experiment with/troubleshoot the OnStar stuff for some other folks here. I believe that the issue is with the antenna/s in the dash cavity. If they are tucked in the wrong way, you'll have issues. I will be removing it again this weekend to see if I can fix #3 by retucking the antenna. The antenna I am referring to is to the right of the radio.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Visual Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Pioneer DEX-P99RS * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 08-28-2012, 02:10 PM   #4
Pace
Lifestyle = Deathstyle
Pace's Avatar
Drives: 11 SIM 2SS/RS
Send a message via AIM to Pace
I am having issue 1. Never thought it could be the Scosche KIT. Hmmmmm. Its a pita as sometimes I want to remote start.
11 2SS/RS
Pace is online now   Reply With Quote
Old 08-28-2012, 02:14 PM   #5
Supermaro585HP
Drives: 2011 Camaro SS RS
I have no issues at all. I didn't install mine but I'm very happy with everything... Good luck.
Supermaro585HP is offline   Reply With Quote
Old 08-28-2012, 02:40 PM   #6
Amarr014
BAD BEE
Amarr014's Avatar
Drives: very fast!
i have issue 1.. pisses me off all the time
2011 V6 LS M6 | straight piped | HIDs | Injen CAI| 75 Shot NX nitrous|Trifecta Tune|RX ported TB,IM and matched heads, Isolator| RX Catch Can | AAC Red Halos | AAC Red interior lighting | Red bowties | 15% tint | Tinted Tails | SS wheels and tires | SS tips| Cat delete| Arc audio 10's| ******** box|Scosche&kenwood|
Amarr014 is offline   Reply With Quote
Old 08-28-2012, 02:46 PM   #7
tjbtexas
tjbtexas's Avatar
Drives: 2012 Camaro 45th Anv. v6 vert
I have issue #1. Drives me crazy when it happens. sometimes I have to be standing by one of the doors to get the trunk open
Mods:CAI,RxCatchCan,Ported TB,Solo-CatBck,Razzi, Technostalgia tail lights,Prado wheels,Escort 9500ci w/ DashTronix HUD projector,AVIC -z140,Scosche,JL Audio Sub/Amp/Spkrs
tjbtexas is offline   Reply With Quote
Old 08-28-2012, 03:16 PM   #8
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
1,2, & 3 for me
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
Old 08-28-2012, 04:30 PM   #9
Rizzo
Thanks for the feedback fellas. I will be pushing these issues from my end and report back as progress is made.
Please let me know if anybody else is seeing issues so I can get tracking info.
Old 08-28-2012, 08:54 PM   #10
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
I have issue 1 also. Thought it was battery but when changed out seems to be the same.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 08-28-2012, 09:01 PM   #11
Horriblecreation
Horriblecreation's Avatar
Drives: 2012 1LT/RS
holy shit.... I definitely have issues 1 and 3, I never even thought of the scosche kit being the culprit.... They definitely started soon after. Man that key fob distance thing kills me! What is the point of a remote start if I start it from arm's length now?!?
A little go, mostly show
Horriblecreation is offline   Reply With Quote
Old 08-28-2012, 10:17 PM   #12
puzzzeler
puzzzeler's Avatar
Drives: 2012 2LS Inferno Orange
Hmmm i have issue #1 thought it was my tinted windows but now not so sure
puzzzeler is offline   Reply With Quote
Old 08-29-2012, 09:02 AM   #13
Rizzo
Good updates. Please keep them coming.
I have forwarded your feedback to my installer so they can send it up to the Scosche engineers.
Old 08-29-2012, 09:08 AM   #14
Horriblecreation
Drives: 2012 1LT/RS
Not sure if this is universal, but mine has a tendency to never shut off the warning dings after I start the car. Its the same sound as the seatbelt warning, but it will not shut off. Figured out that if I flash my hazard lights, it stops the chime, but it will run for as long as the car is on unless you do that. This is probably half the time I start my car.
