Gen5DIY
Old 08-28-2012, 02:50 PM   #1
FresnoStateDogs
FresnoStateDogs's Avatar
Drives: 2012 2SS/RS LS3
Suspension Buckling
I added a one inch drop with new springs. I thought I was being conservative by only going one inch. I was forced to remove my front splitter because when I took it home I couldn't get in my driveway. No big deal. But now I'm noticing a loud buckling sound when taking turns 30mph or faster. I took the car to the dealership after adding springs because I figured they would do the best job. Asked them to re-time my bushing (I left them loose), full suspension check, etc. Is the buckling considered normal for a one inch drop?
Spiral Ported TB, K&N Typhoon, JBA Performance Cat-back, RX catch can and Oil Breather.
FresnoStateDogs is offline   Reply With Quote
Old 08-28-2012, 04:41 PM   #2
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
no
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 08-28-2012, 05:10 PM   #3
Rob@WretchedMS
Drives: His Wife Crazy
no, you should have no noises.
Haddad Motorsports is in Inglewood, maybe you should take it over there to get it looked at.
Rob@WretchedMS is offline   Reply With Quote
Old 08-28-2012, 05:16 PM   #4
FresnoStateDogs
Just noticed the sound only occurs when I turn to the left and consequently when straightening them again. The sound appears to be coming from the left front wheel. I wish it occurred when the car was stopped so that I can determine what is hitting. I don't think the top of the wheel is hitting since it appears to have just as much clearance as the right wheel.
Old 08-28-2012, 05:21 PM   #5
Rob@WretchedMS
Pull off the left front wheel, and go through everything with a wrench and make sure it's all tight.
Pay close attention to the sway bar end links,
Old 08-28-2012, 05:21 PM   #6
FresnoStateDogs
Since I got an alignment at the dealership, shouldn't they be responsible for this issue?
Old 08-28-2012, 05:23 PM   #7
Rob@WretchedMS
hard to say, if it's an install issue then no,
if it's a matter of them leaving something loose, then yes.
It's not common for a car to be brought in to a shop with parts left loose on purpose, so it's possible that something was missed when they tightened it up.
If you can't get a resolution to the issue, Haddad is a Camaro Specialist.
Old 08-28-2012, 06:56 PM   #8
FresnoStateDogs
Took your advice, thanks a billion. Left links were accidentally left loose by the dealership.
