JDP Motorsports
Old 08-28-2012, 03:25 PM   #1
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
anyone use Solar Electric Generation on their home?
We are looking into installing an 80% solar feed system on our home, meaning over a year we generate 80% of our own electricity via solar, and have a NEM (net energy meter) meter installed, this is a two way meter that "runs backwards" when we generate more power than we use.
Before I sign the dotted line I am seeking any experience anyone has with this type of system... any input positive or negative would be helpful.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 08-28-2012, 04:37 PM   #2
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
I wouldn't do it. The up-front cost versus the monthly savings isn't worth it.
What's your current monthly electric bill? What size array do you plan on buying?
Say your monthly electric bill is $200, and say the array costs you $15,000 after all the government tax "incentives." It'll take you over 6 years to recoup your initial investment, and that's not even correcting for inflation.
And that's assuming the array supplies you with 100% of your electricity (which is hardly ever the case).
If you use the 80% number, that means it will actually take closer to 8 years to recoup the cost. And that's just in that example. The specifics of your situation may be vastly different, hence my initial questions.
My VIN = 2G1FK1EJ9A9105017
Old 08-28-2012, 04:52 PM   #3
Quackersacker
Quackersacker's Avatar
Drives: 2011 Camaro Convertible SS
It could be up to 8 years but depends on state and uitlity incentives. Just put some on my business and pay back is going to be 3 years with all of the incentives. I look at it this way also it fixes my utility cost, if you dont plan on moving then for the next 25 years you are only going to pay so much for a percentage of your electrical use.
In Iowa we have lots of propane tanks (pigs) and its always best to fill them in august when cost are the least. Look at purchasing the solar to this regard. Not an investment.
Hell if you put your money in the bank only get 1 - 2 percent right now at best.
Quackersacker is offline   Reply With Quote
Old 08-28-2012, 04:58 PM   #4
CamaroSkooter
I imagine electric bills in SoCal aren't exactly cheap, but I don't know how the same SoCal market affects the prices of solar arrays (or the price to install).
What are the maintenance costs of a solar array? I doubt you can just put one on the roof and then forget about it for 25 years...
Old 08-28-2012, 05:04 PM   #5
Quackersacker
For the photovoltaic panels, yes pretty much maintenance free. Solar heating on the other hand is subject to leaks and inspections.
For the electric, as long as you get some rain they clean themselves. Only thing that really can go wrong are the inverters. Turning the DC to AC creates heat and can be an issue but they even come with a 5 year warranty, panels 25 years.
Old 08-28-2012, 05:12 PM   #6
Mr. iNCREDIBLE
The system is $18K to install, with $6,500 in rebates so $11,500 end cost..
I pay $350 - $500 a month for electric from May until Oct and $250 or so Oct-May. 2000 sq ft home with a 4-ton HVAC set to 85° during peak and 78° off-peak.. My wife is a home maker and 85° when it is high 90° outside during the summer is not comfortable for her (or my kid or the dogs), dropping the HVAC to 78° puts us into the $600 range for a month. Add to that, SCE (Southern California Edison) has had roughly a 3.75% over standard inflation rate increase yearly since 2002, my current $350ish bill will be well over $1000/month in 10 - 15 years.
Last year my electrical usage was just a bit over $5,000 so my "pay back" would be 2-3 years..
This is my last house, I was in my previous home for 24 years, plan on being here until I die, so at minimum another 30 years. I'm not a mover, we found our dream home and plan on staying, no reason not to make it as automated, efficient, and comfortable as possible for us.
As I understand it an 80% system is averaged over the whole year and based on 5 hours/day of peak sunlight, the solar irradiance test SCE did to our home shows we have 7.8 to 9.6 hours/day as the home faces East/South East. So a 100% system is overkill, however we are setting the inverter and braces up so we can if the need arises we can add up to 6 more panels in the future to create a 100% system.
Old 08-28-2012, 05:21 PM   #7
2010SSRSM6
2010SSRSM6's Avatar
I had a 9.3Kwh system installed two months ago and my bill was $200 last month. From 10am-5 pm I'm producing more electric then I'm using. After that, its all SCE. It will pull me out of the tier 4-5 parts but that is it during the summer months, but the rest of the year I should be golden.
If you have that price in writing, jump on it. The idiots in charge are adding a 35% TAX onto each panels price, so get it while you can.
I went with Solar Service Center. I talked to Sullivan, Solar City and someone else and they were the best deal going. Let me know if you need a contact number.
Old 08-28-2012, 05:22 PM   #8
CamaroSkooter
Sheesh. Those are crappy electric bills
A 1,700 SF house here (like the one I'm about to build) typically only sees about $200 per month max.
But if that's the kind of cost you're seeing in SoCal, I can see it being viable.
Have you checked out any other homes in the area with the same (or similar) system that have had them for a while (more than a year)?
Old 08-28-2012, 05:26 PM   #9
Quackersacker
I assume this is a roof mount. So you may have to at sometime remove to work on roof. Dont size the inverter for expansion. No need to do so. Size wiring conduits, braces for expansion but not inverter. Reason not to is so if you do expand and something happens to your inverter you wont have any production if you go with 2 inverters youll still have some. Inverter prices are likely to go down in time "supply and demand" Just my 2 cents.
Old 08-28-2012, 05:26 PM   #10
Mr. iNCREDIBLE
that's the problem, only solar around me seems to be for pool heating, not electrical generation.. hence my thread seeking some insight.
Old 08-28-2012, 05:27 PM   #11
2010SSRSM6
2010SSRSM6's Avatar
Most of the companies are offering a 20-25 year warranty on the panels, install and monitoring. If they aren't, they are not worth the time it takes to tell them to pound sand.
Our elected idiots just put a 35% TAX on all solar panels so the price is getting ready to go through the roof. They are trying to "hurt" China by taxing the products that they supply to the US. All that happens is it gets passed on to us, the consumer.
My average summer electric bill in So Cal is over $500. Large house (only 4 years old but 3650 sqft), pool and I work nights so my AC runs all day long.
Old 08-28-2012, 05:33 PM   #12
2010SSRSM6
2010SSRSM6's Avatar
What area are you in? I'm in the Temecula area. There are 4-5 people that I know that have had their systems installed or will be installing their systems in the next month.
A buddy of mine's roof didn't provide a great amount of surface facing the right direction and they are only getting 9 panels. Every little bit helps when you get raked over the coals for electric.
Old 08-28-2012, 06:02 PM   #13
Mr. iNCREDIBLE
i'm in Downey, just north of Long Beach.. I have enough surface area on the east and southeast sides for 30+ panels.. we are starting with 14..
roof was just put on in March so with it's 25 year and the solar 25 year warranty hopefully I won't have any issues insofar and requiring the panels to come off.
Old 08-28-2012, 06:09 PM   #14
2010SSRSM6
2010SSRSM6's Avatar
I think I was told the south facing parts of the roof net the most production from the systems for where I'm located. You aren't very far south of me so I'm assuming it will be the same for you.
The system I went with uses inverters on each panel, rather than using a large one mounted on the side of the house. If it wasn't for the long warranty, I wouldn't have gone that route, but with the monitor being able to see each panel's output and the company is "Guaranteeing" output, I didn't feel like I had anything to loose.
