Cold Air Inductions
Old 08-28-2012, 11:08 PM   #1
kstormoen
Drives: Camaro SS2 L99
Misfire - need help
I need help figuring this one out. When I start the car up after sitting for the night the car has a slight miss on light acceleration. It goes away after about .5 miles and then the car runs fine. It doesn't happen all the time, but it does happen most of the time. I noticed shortly after I installed LT Headers by dynamax. Here are my mods
Whipple
Rotofab CAI
Dynamax off road LT (No Cats)
vmax ported tb.
jannetty Tune
Here is what I have done to diagnose.
Talked to ted about the miss. He had me datalog, found out cylinder 2 & 8 had a misfire. We determined it isn't in the tune and must be mechanical.
changed plug wires, cleaned CAI, clean MAF - no change, same cylinders are misfiring.
Changed Plugs, did compression test & Leak down test, and check whipple for vac leaks - Plugs looked black so I changed them and it still has a miss. I haven't datalogged to see if it is same 2 cylinders, but I'm sure it is.
Mechanic said that my headers are hitting the floor boards because he could hear it??? any help would be awesome.
Thanks
Keith
kstormoen is offline   Reply With Quote
Old 08-29-2012, 06:26 AM   #2
MA2010SS
Drives: 2010 Camaro SS
Double check the plug wires, make sure they are seated properly, check resistance accross all plug wires make sure they are all close to the same resistance, take coils #2 and #8 and move those coils to another cylinder data log again and see if the misfire follows the coils or if the misfire is still occuring within those cylinders
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 08-29-2012, 08:48 AM   #3
kstormoen
ok, thanks. I will report the results. Thanks ma2010ss
Keith
Old 03-06-2013, 07:53 AM   #4
zero260asap
2010 1SS I had a misfire on cold startup that would throw the checkengine and service stabilitrac. it lasted about 20 seconds then the car would run fine and the lights would go off. dealer said to do a fuel injection cleaning so i did (knew that wouldn't work it has 25 k on it lol) I've brought it back twice since then, and just got a call today GM gave the go ahead to replace the head because of valve grinds that could cause sticking on start up.
zero260asap is offline   Reply With Quote
Old 03-06-2013, 09:16 AM   #5
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Whipple
Rotofab CAI
vmax ported tb.
jannetty Tune
Thanks
Keith
Great Advice,
Also a Leak down test and compression test will rule out any engine mechanical issues that may be hiding behind a warmed up engine.
The only thing left after that would be injectors, or dirt in the injector screens.
I can raise the misfire threasholds in the tune but that would only cover up the problem which we don't want to do.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 03-06-2013, 03:10 PM   #6
zero260asap
Yep the valves on driver side were sticking they said even one of the valve springs was cracked because of it.
