Anthony @ LG Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic > Local Marketplace
Old 08-29-2012, 11:04 AM   #1
calinkaos
Army EOD Vet
calinkaos's Avatar
Drives: 2010 2SS/RS blk/blk/blk
L99 MTI Stage I Camshaft $200
I will be pulling my MTI installed and tuned Stage I uni-cam from my camaro. I am installing heads and cam package and a LS3 conversion kit.
So lucky camaro owners out there looking for a much more aggressive and lopey sounding camaro get this sweet upgrade for only 200$. Does Not need a stall converter on stock L99 engines. It is however a 3bolt cam, so L99s will need a 3bolt front swap. I can toss in a few parts for an extra charge if interested. Any questions PM me. or form thread.
(following is from MTI Racing website)"At MTI Racing, we refer to this as the "Un-Cam" because it drives almost exactly like stock. This camshaft is designed specifically to take advantage of the awesome airflow potential of the LS3 cylinder head. Subsequent testing has revealed that it is also an excellent choice for L99 equipped automatic transmission Camaros.
MTI Racing Stage 1 Camshaft Specs are: 223/231 .610/.617
Mild to Moderate idle sound and great performance. Best results achievable with Headers and Cold Air Induction. We suggest the use of Dual Springs with this camshaft. Price $389.00"
2010 2SS/RS Blk/Blk Camaro F1A Procharger
calinkaos is offline   Reply With Quote
Old 08-29-2012, 09:09 PM   #2
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Are you able to share the performance you had with the cam? Hp and such? What other mods did you do inside the block when you got it? Springs, etc...?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 08-30-2012, 05:47 PM   #3
calinkaos
Army EOD Vet
calinkaos's Avatar
*WRONG DYNO SHEET!*
This is not my dyno sheet but this is the same mods roughly, I cant find my sheet tho.
My Mods:New Era intake, JBA long tube and hi flo cats, corsa catback.
If you are seriously interest come drive my car sometime. I will be around at the car shows and cruises in stafford area.
Old 08-30-2012, 07:55 PM   #4
edog
edog's Avatar
Is this with the CAM, or before the cam?
Old 08-30-2012, 09:48 PM   #5
thesnoopster
thesnoopster's Avatar
Drives: '10 SIM SS/A6 - '12 SIM Equinox LT
That looks like a dyno without the cam. I would love to see how it sounds (I love a cammed car sound)
2010 SIM Camaro 1SS/A6
Mods: "93 Octane and a baby seat..." TunedByFrost/EFI Performance,LLC @ PAS "You gotta love me ... or leave me alone"
Old 08-31-2012, 09:49 AM   #6
calinkaos
Army EOD Vet
calinkaos's Avatar
Actually I just found the forum they posted...
http://www.camaro5.com/forums/showthread.php?t=97497
This is my dyno sheet at MTI, and still making 22MPG! Granted thats their tune, but I am sure someone local can match it.
Old 08-31-2012, 09:59 AM   #7
calinkaos
Army EOD Vet
calinkaos's Avatar
If you are interested in seeing the car I will be at this cruise-in on Sunday. Bring out your clean ride and check out others. (majority is american muscle!)
MCCA Cruise-In (Woodbridge, VA)
Sept 2, 2012
3:30pm until 5:30pm..
Burger King, 16551 River Ridge Blvd, Woodbridge, VA 22191
Old 08-31-2012, 07:35 PM   #8
calinkaos
Army EOD Vet
calinkaos's Avatar
Cam will come worry matching mti springs. I will changing out mine with the package I just bought.
Old 09-01-2012, 08:48 AM   #9
edog
edog's Avatar
That is definitely what i was hoping. I am at the same hp without camcam from the first sheet. The bump for me on something like this would be around another 36hp.
Great, i like the dyno. I am like you, and want a bit more. It is right around the corner for me. Thanks for sharing the info.
