Caryle Racing
Old 06-19-2009, 01:41 PM   #29
ssalter
Drives: 2010 2ss/rs iom w/ blk & iom
Originally Posted by JDBeck23 View Post
TLSTWIN, that's easy, I'll post it up as soon as I get my car, I'll jumper the hot side of the side marker/halo lights relay to the hot side of the fog lights relay. It's that simple. I've done it on every car I've had that came with foglights
yea please let me know as well, because i will definently do this, but i would rather get the non rs headlight switch and be able to switch them, also
wonder what bulb size the fogs are so an HID kit could be bought??
ssalter is offline   Reply With Quote
Old 06-19-2009, 01:47 PM   #30
Matt'sSS
From 2 door to 5 door
Matt'sSS's Avatar
Drives: C5 Vert->CGM SS RS M6->SRT8 Magnum
I'm sure the fog's will be an industry standard size. I might look into something like Silverstars to just match the HID color first, but will probably just go with a slim HID upgrade kit since it's already got that convenient battery terminal post in the engine bay.
Matt'sSS is offline   Reply With Quote
Old 06-20-2009, 01:50 PM   #31
oilsandsoilfan
oilsandsoilfan's Avatar
Drives: 1969 Z28 and 2010 2SS, Ls3 6sp
Thanks for the info, I have my amps and subs ready to go just need my car.
oilsandsoilfan is offline   Reply With Quote
Old 07-08-2009, 04:48 PM   #32
ss1 inferno
Drives: cool
What about a car alarm?
Can i install a viper car alarm? my dealership told me that i shouldn't because the wiring is different and they are compatible and that gm hasn't even made a alarm system for the camaro so we should just wait till they make one
I think its kinda a bunch of crap what do youll think?
ss1 inferno is offline   Reply With Quote
Old 07-08-2009, 04:52 PM   #33
ss1 inferno
Drives: cool
mistake i mean are not compatible
Old 07-08-2009, 04:55 PM   #34
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I think you can install anything you want. We have the info of how to wire it, so why not install something to protect your investment?
ZZcamaro is offline   Reply With Quote
Old 07-08-2009, 11:55 PM   #35
SicSix6
The Demon Photographer
SicSix6's Avatar
Drives: 2010 1SS IOM Camaro
Where is the factory alarm module located?
The 4th gen one was in the passenger rear area near the spare tire....
1SS IOM LS3, GM 4-pack guages, SLP SS Front Emblem, Roto-Fab CAI, Solo Performance Mach X Exhaust, Barton Industries Short Throw Shifter
SicSix6 is offline   Reply With Quote
Old 07-16-2009, 09:30 AM   #36
fitzgerald69
Drives: Victory Red 1LT/RS
Do you have this in a PDF or other file format where I could print it off?
fitzgerald69 is offline   Reply With Quote
Old 07-16-2009, 10:39 AM   #37
ZZcamaro
not in PDF. just save each picture and print it...or down load a cheap converter...i believe it is called cute pdf....you could use that to convert it and print it out.
Old 10-30-2009, 11:18 PM   #38
FAF
Member
FAF's Avatar
Drives: 2010 Camaro, 2008 Tundra
great info thanks
[/SIGPIC]2010 Camaro 2LT / RS - IMO, CF5, M6
1100 1/29/09, 6000 6/22/09 ; sunroof; Airaid CAI; Corsa Performance CAT Back; Hurst Short-throw shifter; LoJack; Dash ABL Mod; ********; AACStyle LEDs; calipers red covers;
FAF is offline   Reply With Quote
Old 02-24-2010, 01:37 PM   #39
GQ4Life
Drives: 2010 Camaro SS LS3
thanks.. got what I needed.. the BCM driver unlock motor & lock motor.. U rock..
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 03-01-2010, 08:23 AM   #40
mmongi7
Drives: 2010 Camaro 2LT
Send a message via AIM to mmongi7
Definately needed these wiring colors explained. Thanks!
Camaro 5 Fest here I come!
mmongi7 is offline   Reply With Quote
Old 03-14-2010, 11:21 PM   #41
Bryon Anderson
Drives: 2010 ssrs camaro black
I have a question- my SSRS from ground to the top of the wheel well is 31in and my friend has a SS and his is 30in. Anyone know why? (Same rims and tires)
Bryon Anderson is offline   Reply With Quote
Old 03-26-2010, 10:05 PM   #42
Cam58
Drives: 2010 Camaro
Where can I splice into the front speaker wires to hook into an amp I am installing? It looks difficult to access the back of the stereo.
Cam58 is offline   Reply With Quote
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
Some thoughts on "recent" developments on this site.... fbodfather 5th Gen Camaro SS LS LT General Discussions 258 05-08-2009 11:24 PM
