Jason 98 TA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 08-29-2012, 04:51 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2010 X5 Camaro Turbo
'PFADT' Camaro ZL-spec Adjustable Sway Bars @ Phastek Performance
'PFADT' Camaro ZL-spec Adjustable Sway Bars (Front And Rear) #1410138 :: 2010-2013 Camaro*
2012 Camaro ZL - spec Adjustable Sway Bars (Front And Rear) #1410138 by PFADT
With the release of the 2012 Camaro FE4/ZL1 suspension packages we knew we could offer another big step forward in the balance of these cars. The result of the change is our new ZL Spec Sway Bar Package! We have always wanted to decrease body roll even over the previous bar packages, and the revised FE4 sway bar geometry has allowed us to build the bar package we've always wanted to. With the 2012 Camaro, GM revised the sway bar pick up points and they are now outside of the rear shock, rather than inside like on the older 2010/2011. This allowed us to revisit what's really important in a street and competition ready sway bar package, our primary goals were:
Significant decrease in body roll, without big impacts to ride quality.
Improved balance
Adjustable front and rear bar for those who want to get the best performance out of their cars
Easy Installation
Bushings Included
Best materials and engineering available on the market
Being both lighter and stronger than the factory sway bars
Our ZL Spec FE4/ZL1 sway bars share the same great features you would come to expect from a Pfadt Race Engineering product. They feature high strength, hollow chromolly tube design with our specially designed bar ends. The hollow bar design allows us to keep weight down without impact to strength or longevity, and the specially designed precision machined bar ends finally allow for an adjustable FE4/ZL1 rear sway bar that can still reuse your factory FE4/ZL1 rear endlinks. While significantly increasing bar stiffness we've still managed to lose 6lbs of weight off the rear sway bar, and a little over 1lb off of the front bar. Being lighter and stronger to make you faster is what the new ZL Spec sway bar package is all about!
*This product is a direct bolt on for 2012+ ZL1.
*2012+ Camaro SS will need Pfadt Front Endlink Kit (part number 1410139) to complete installation.
*2010 and 2011 Camaro SS will need to upgrade to the new GM designed FE4 lower control arms AND Pfadt Front Endlink kit, which are available together as a package from Pfadt (part number 1410140) for simple installation.
*This product will NOT fit any year V6 Camaro without upgrading to the V8 Brembo rear brake package.
Place your orders at www.PhastekPerformance.com
Sales@Phastek is online now   Reply With Quote
