JUICEDMOTORSPORTS
Old 08-30-2012, 07:51 AM   #15
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
Originally Posted by JEFF75645 View Post
The car in the BBK video has a CAI , x pipe, and LT headers and made those numbers with the stock tune. In the link I posted above you can see this along with the Dyno run. FWIW
much betta
Higgs Boson is offline   Reply With Quote
Old 08-30-2012, 10:53 AM   #16
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
Originally Posted by Higgs Boson View Post
dyno of either one??
a guy posts two numbers with no supporting documentation so that's what it makes? engine hp or wheel hp? on a stock car or modified? etc.
dude, there are questions to be asked before you swallow it whole.
V-Max has a video of the before and after dyno pulls with their p&p TB. They made 9hp and 11tq to the wheels. You can see the video on YouTube. I saw one BBK video a while back with a dyno run of their TB. But sometimes BBK videos are more like commercials with the intent to sell their product as opposed to being factual and informative...IMO. And a lot of times they group several different mods together instead of one particular mod. But I see how my question gave the wrong idea. I wasn't taking it as fact, I was asking if the gains were true and comparable to V-Max's proven gains. I just phrased it wrong.
2017 Camaro ZL-1 A10 - Roto-Fab cai - Katech ported TB - MBRP Race catback!!
2017 Challenger Hellcat M6 - Legmaker CAI - MMP ported TB!!
Saving the world...1 hp at a time!!
BlaqWhole is online now   Reply With Quote
Old 08-30-2012, 11:07 AM   #17
Higgs Boson
in the ZL1 Market
everything is a sales job!
either way, i'd like to see a head to head between the bbk and the vmax.
Vmax claims no need to tune for a TB resize so it is still a 90mm??
BBK is 95mm so you would want to tune the car so it will idle properly.
Discussion on this?
Old 08-30-2012, 12:26 PM   #18
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Also If bbk says its a 95mm tb then is there any modifications needed for the intake? Does it need opening up? Or is the outside diameter "95mm" and then shrinks back to a 90mm? If that's the case what is the point?
Further discussion topics lol
Old 08-30-2012, 12:39 PM   #19
JEFF75645
Drives: his wife crazy buying mods
Just buy one and let us know how it goes.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 08-30-2012, 12:50 PM   #20
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Naa I'm a pesamist lol
I believe in tunes, certain CAI's, long tube headers, med/big cams, cylinder heads and gears!
The rest are gimmicks lol.
Old 08-30-2012, 12:57 PM   #21
JEFF75645
I saw these several months ago but opted just to send my intake and TB off to be ported for cheaper than the BBK TB. I think it was around 300.00 for both ported.
Old 08-30-2012, 01:10 PM   #22
Coyotekiller
Drives: 2012 AGM 2SS
I thought factory intake was 95mm?
As for the reason I want this one over the vmax right now is mostly because I don't want a polished part. If air truly flows better over rough machined surfaces, then why does vmax polish their throttle bodies?
Coyotekiller is offline   Reply With Quote
Old 08-30-2012, 01:11 PM   #23
JEFF75645
Hmm. I thought they were 90mm.
Old 08-30-2012, 01:18 PM   #24
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
They are 90mm fellas.
Old 08-30-2012, 01:38 PM   #25
BlaqWhole
BlaqWhole's Avatar
I'm not the authority on this, but I think it mainly depends on the type of engine. I believe some engines make more power with turbulent air while other engines make more power with smoother airflow...
Old 08-30-2012, 02:29 PM   #26
2010SSRSM6
SoCal C5 Family Member
2010SSRSM6's Avatar
How long have these been out? Any advantage to these over the V-max?
They started testing them almost 2 years ago. If there was a problem, it would have come to the surface by now. I don't think they are putting the focus on advertising the GM line as much as they do the Mustang stuff because that is their primary market. I'm sure it doesn't help that their production facility isn't that large and they make a TON of stuff.
When BBK was formed, it was for the Mustang. They are trying to branch out, it is just going slower than they would like, mostly due to the economy. Where it's just a TB (no electronics), I can't see it having an issue. It uses all the factory electronics.
UNDER CONSTRUCTION. ETA 2017 ish...
Old 08-30-2012, 02:43 PM   #27
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Would this require a retune? Wonder if it would make any noticeable difference going from the Vmax to this?
E.T. is offline   Reply With Quote
Old 08-30-2012, 03:28 PM   #28
Ivan @ Southwest Speed
...and if they were such a bangin product then maybe BBK would be the company instead of Rx/VMax having weeks long waiting lines for their TBs.
Just an observation.
Ivan
